| 0002553 | Path | Feature | public | 2016-05-13 22:06 | 2018-05-13 16:28 |
| Reporter | sliptonic | Assigned To | mlampert | ||
| Summary | 0002553: 4th axis paths don't display as expected | ||||
| Description | Issue imported from https://github.com/yorikvanhavre/FreeCAD/issues/7 sliptonic commented on 14 Dec 2014 4th axis paths don't display as expected In the image, you can see a 2 axis gcode file that has had the Y axis coordinates mapped onto th A axis. Gcode Ripper is able to display the gcode as it would appear. This is done by selecting the view plane (ISO1). User should be able to visualize the path as it would appear. selection_028 | ||||
sliptonic commented on 15 Dec 2014 Here's a 4th axis toolpath. https://dl.dropboxusercontent.com/u/9245675/fish_wrap.ngc |
yorikvanhavre commented on 29 Dec 2014 I'm not sure how this should be done? Isn't it better to have a special pre_ script that maps all A values to Y? |
sliptonic commented on 29 Dec 2014 No, that would undo what we're trying to do. Gcoderipper is easy to install and can be downloaded here: http://www.scorchworks.com/ It's the program running in the middle of the image above. It has a number of interesting features for working with paths. In this case, it's taking a 2D path in XYZ and mapping the Y axis moves onto A axis with a given diameter. This effectively 'wraps' the engraving around the cylinder. However, if I import that path into FreeCAD, it doesn't look like the wrapped cylinder since no A moves are shown. Somehow, GcodeRipper addresses this with the ISO views. |
yorikvanhavre commented on 29 Dec 2014 I can't make the g-code ripper program display the same thing as in your screenshot with the file linked above... It keeps telling me "Aborting G-Code Reading: A Codes are not supported". Is there any other option to configure? Anyway it is still not clear to me what we need to achieve, if it is not mapping the A values to X or Y? |
yorikvanhavre commented on 29 Dec 2014 (18:01:42) sliptonic: Here's an application. https://www.youtube.com/watch?v=dblNnF4JJGk Ideally, the path visualization after wrapping would look something like this: http://www.cnczone.com/forums/attachment.php?attachmentid=90480&stc=1&thumb=1&d=1389517864 (18:06:08) sliptonic: Another image: http://www.cnczone.com/forums/attachment.php?attachmentid=186056&d=1389534069&thumb=1 |
yorikvanhavre commented on 11 Apr 2015 This is not that easy... It really involves building a complex, new display mode to show/map the paths on a cylinder... I suggest we leave that for after the merge |
Moving to 0.18 target |
https://github.com/FreeCAD/FreeCAD/pull/1450/commits/352ba3b0a8500a75f953fa39fbe2cb3327ae9c71 |
| 2016-05-13 22:06 | yorik | New Issue | |
| 2016-05-13 22:06 | yorik | File Added: 0178ba9c-83a2-11e4-933d-f891256e1317.png | |
| 2016-05-13 22:06 | yorik | Reporter | yorik => sliptonic |
| 2016-05-13 22:06 | yorik | Note Added: 0007101 | |
| 2016-05-13 22:07 | yorik | File Added: fish_wrap.ngc | |
| 2016-05-13 22:07 | yorik | Note Added: 0007102 | |
| 2016-05-13 22:07 | yorik | Note Added: 0007103 | |
| 2016-05-13 22:08 | yorik | Note Added: 0007104 | |
| 2016-05-13 22:08 | yorik | Note Added: 0007105 | |
| 2016-05-13 22:08 | yorik | Note Added: 0007106 | |
| 2017-02-04 03:50 | Kunda1 | File Added: 0178ba9c-83a2-11e4-933d-f891256e1317.jpg | |
| 2017-02-04 03:51 | Kunda1 | File Deleted: 0178ba9c-83a2-11e4-933d-f891256e1317.png | |
| 2017-11-28 00:57 | sliptonic | Product Version | 0.16 => |
| 2017-11-28 00:57 | sliptonic | Target Version | => 0.18 |
| 2017-11-28 00:57 | sliptonic | Note Added: 0010486 | |
| 2018-05-08 21:28 | mlampert | Assigned To | => mlampert |
| 2018-05-08 21:28 | mlampert | Status | new => assigned |
| 2018-05-08 21:29 | mlampert | Note Added: 0011240 | |
| 2018-05-11 20:41 | mlampert | Status | assigned => resolved |
| 2018-05-11 20:41 | mlampert | Resolution | open => fixed |
| 2018-05-11 20:41 | mlampert | Fixed in Version | => 0.18 |
| 2018-05-13 16:28 | wmayer | Status | resolved => closed |
