| 0002561 | PartDesign | Bug | public | 2016-05-24 08:19 | 2017-07-15 11:20 |
| Reporter | Jean-Luc | Assigned To | wmayer | ||
| OS | Debian GNU/Linux | OS Version | sid/Linux 4.6 | ||
| Summary | 0002561: SIGSEGV while moving an entity from a body to an other one | ||||
| Description | Hi, This apply to latest git master version (I've not found it in "Product version" box. Version: 0.17 Revision: 7667 (git) FreeCAD crashes with e SIGSEGV while moving a box from a body to another one in the same part. | ||||
| Steps To Reproduce | I start in PartDesign - Create a new part - Create 3 bodies under this part - Create a box in the third body - Move the box from the 3rd body to the first one (right click -> move object to another body -> choose the 1st in the list) ---> Crash ** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 1a0 | ||||
The crash happens in the method CmdPartDesignMoveFeature::activated on line 636:
because 'sourceNewTip ' is a nullptr. Btw, to me this block doesn't make much sense anyway because in line 619 the Tip is removed from 'source' but nothing has been added to it. So, why is there a second call to get its Tip (when it actually must be null).The code can be easily fixed by adding
but when trying the example with the three bodies and a box, the box will be moved but not its attached coordinate system. So, to me it seems more things are broken in this command (or I don't understand the logic :) ). |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20370 |
Doesn't seem to happen with: OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10232 +1 (Git) Build type: Debug Branch: constraintselect Hash: aa748cdfa847e4ca2cd4e59bc0910347d5bf977e Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
@kunda1 This can not be reproduced anymore. I guess Werner fixed it in the meantime. I think this ticket should be closed. |
Thanks @Abdullah @wmayer any idea what git commit you fixed this with? Resolving in the meantime. |
| 2016-05-24 08:19 | Jean-Luc | New Issue | |
| 2016-05-24 16:41 | wmayer | Note Added: 0007120 | |
| 2016-05-24 16:41 | wmayer | Status | new => confirmed |
| 2017-01-30 16:12 | Kunda1 | Note Added: 0008109 | |
| 2017-02-20 22:01 | Kunda1 | Target Version | => 0.17 |
| 2017-02-23 21:06 | jnxd | Note Added: 0008413 | |
| 2017-05-24 22:03 | abdullah | Note Added: 0009119 | |
| 2017-05-24 22:06 | Kunda1 | Assigned To | => wmayer |
| 2017-05-24 22:06 | Kunda1 | Status | confirmed => resolved |
| 2017-05-24 22:06 | Kunda1 | Resolution | open => fixed |
| 2017-05-24 22:06 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-05-24 22:06 | Kunda1 | Note Added: 0009120 | |
| 2017-07-15 11:20 | Kunda1 | Status | resolved => closed |
