0002568FreeCADBugpublic2017-08-13 16:46
ReporterKarenRei Assigned To
PlatformFedora 22
Summary0002568: FreeCAD doesn't clean up after itself when it crashes (when /tmp is full = FC++ exception)
DescriptionI run gmsh, max element size 50, create mechanical analysis from mesh, on the attached file. It exits strangely fast. I then can no longer save the document - every time I try I get "FC++ exception thrown (SMESH Exception : Smesh Exception)"
Steps To ReproduceSee above
Additional InformationOS: "Fedora release 22 (Twenty Two)"
Version: 0.17.7680 (Git)
Build type: Unknown
Hash: 966ce79207da593db8a7848e23c82f4d3baad27c
Python version: 2.7.10
Qt version: 4.8.7
Coin version: 3.1.3
OCC version: 6.7.1.oce-0.16
Tagsexception
KarenRei
2016-05-30 01:21
reporter   ~0007127
Forgot to attach the file... but more importantly, I think I've figured this one out: /tmp was full. So I think the problem here is actually "need a better error message" :)
KarenRei
2016-05-30 22:23
reporter   ~0007131
Beyond "needs a better error message", there's another problem: FreeCAD doesn't clean up after itself when it crashes (and it's been crashing a lot), it just leaves junk in /tmp. So there's really two things here, it also needs to clean up after itself.
2017-01-17 01:23
administrator   ~0007825
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19964
2017-06-16 12:35
administrator   ~0009408
@KarenRei please attach file. If it's too large use a 3rd party cloud service. Thanks
2017-06-28 14:21
administrator   ~0009576
@KarenRei please respond
2017-08-13 16:46
administrator   ~0009912
Closing as OP wasn't responsive and issue hasn't presented.
2016-05-30 01:17 KarenRei New Issue
2016-05-30 01:21 KarenRei Note Added: 0007127
2016-05-30 22:23 KarenRei Note Added: 0007131
2017-01-17 01:23 Kunda1 Note Added: 0007825
2017-02-02 21:32 Kunda1 Summary FC++ exception thrown (SMESH Exception : Smesh Exception) => FreeCAD doesn't clean up after itself when it crashes (when /temp is full = FC++ exception)
2017-02-02 21:32 Kunda1 Tag Attached: exception
2017-02-02 21:33 Kunda1 Summary FreeCAD doesn't clean up after itself when it crashes (when /temp is full = FC++ exception) => FreeCAD doesn't clean up after itself when it crashes (when /tmp is full = FC++ exception)
2017-06-16 12:35 Kunda1 Note Added: 0009408
2017-06-16 12:35 Kunda1 Status new => feedback
2017-06-28 14:21 Kunda1 Note Added: 0009576
2017-08-13 16:46 Kunda1 Status feedback => closed
2017-08-13 16:46 Kunda1 Resolution open => unable to reproduce
2017-08-13 16:46 Kunda1 Note Added: 0009912
