0002570FreeCADBugpublic2017-03-07 12:49
ReporterKarenRei Assigned Toberndhahnebach
PlatformFedora 22
Summary0002570: Crash when running gmsh
DescriptionRunning: /usr/local/bin/gmsh /tmp/tmpU4gXP1.step -3 -format unv -o /tmp/Mesh070001_Mesh.unv -algo netgen -clmax 80,00 -clmin 2,00 -optimize -order 2Info : Running '/usr/local/bin/gmsh /tmp/tmpU4gXP1.step -3 -format unv -o /tmp/Mesh070001_Mesh.unv -algo netgen -clmax 80,00 -clmin 2,00 -optimize -order 2' [Gmsh 2.12.0, 1 node, max. 1 thread]
Info : Started on Mon May 30 18:16:36 2016
Info : Reading '/tmp/tmpU4gXP1.step'...
Info : Done reading '/tmp/tmpU4gXP1.step'
Info : Meshing 1D...
Info : Meshing curve 1 (Line)
Info : Meshing curve 2 (Line)
Info : Meshing curve 3 (Line)
Info : Meshing curve 4 (Line)
Info : Meshing curve 5 (Line)
Info : Meshing curve 6 (Line)
Info : Meshing curve 7 (Line)
Info : Meshing curve 8 (Line)
Info : Meshing curve 9 (Line)
Info : Meshing curve 10 (Line)
Info : Meshing curve 11 (Line)
Info : Meshing curve 12 (Line)
Info : Meshing curve 13 (Line)
Info : Meshing curve 14 (Line)
Info : Meshing curve 15 (Line)
Info : Meshing curve 16 (Line)
Info : Meshing curve 17 (Line)
Info : Meshing curve 18 (Line)
Info : Meshing curve 19 (Line)
Info : Meshing curve 20 (Line)
Info : Meshing curve 21 (Line)
Info : Meshing curve 22 (Line)
Info : Meshing curve 23 (Line)
Info : Meshing curve 24 (Line)
Info : Meshing curve 25 (Line)
Info : Meshing curve 26 (Line)
Info : Meshing curve 27 (Line)
Info : Meshing curve 28 (Line)
Info : Meshing curve 29 (Line)
Info : Meshing curve 30 (Line)
Info : Meshing curve 31 (Line)
Info : Meshing curve 32 (Line)
Info : Meshing curve 33 (Line)
Info : Meshing curve 34 (Line)
Info : Meshing curve 35 (Line)
Info : Meshing curve 36 (Line)
Info : Meshing curve 37 (Line)
Info : Meshing curve 38 (Line)
Info : Meshing curve 39 (Line)
Info : Meshing curve 40 (Line)
Info : Meshing curve 41 (Line)
Info : Meshing curve 42 (Line)
Info : Meshing curve 43 (Line)
Info : Meshing curve 44 (Line)
Info : Meshing curve 45 (Line)
Info : Meshing curve 46 (Line)
Info : Meshing curve 47 (Line)
Info : Meshing curve 48 (Line)
Info : Meshing curve 49 (Line)
Info : Meshing curve 50 (Line)
Info : Meshing curve 51 (Line)
Info : Meshing curve 52 (Line)
Info : Meshing curve 53 (Line)
Info : Meshing curve 54 (Line)
Info : Meshing curve 55 (Line)
Info : Meshing curve 56 (Line)
Info : Meshing curve 57 (Line)
Info : Meshing curve 58 (Line)
Info : Meshing curve 59 (Line)
Info : Meshing curve 60 (Line)
Info : Meshing curve 61 (Line)
Info : Meshing curve 62 (Line)
Info : Meshing curve 63 (Line)
Info : Meshing curve 64 (Line)
Info : Meshing curve 65 (Line)
Info : Meshing curve 66 (Line)
Info : Meshing curve 67 (Line)
Info : Meshing curve 68 (Line)
Info : Meshing curve 69 (Line)
Info : Meshing curve 70 (Line)
Info : Meshing curve 71 (Line)
Info : Meshing curve 72 (Line)
Info : Meshing curve 73 (Line)
Info : Meshing curve 74 (Line)
Info : Meshing curve 75 (Line)
Info : Meshing curve 76 (Line)
Info : Meshing curve 77 (Line)
Info : Meshing curve 78 (Line)
Info : Meshing curve 79 (Line)
Info : Meshing curve 80 (Line)
Info : Meshing curve 81 (Line)
Info : Meshing curve 82 (Line)
Info : Meshing curve 83 (Line)
Info : Meshing curve 84 (Line)
Info : Meshing curve 85 (Line)
Info : Meshing curve 86 (Line)
Info : Meshing curve 87 (Line)
Info : Meshing curve 88 (Line)
Info : Meshing curve 89 (Line)
Info : Meshing curve 90 (Line)
Info : Meshing curve 91 (Line)
Info : Meshing curve 92 (Line)
Info : Meshing curve 93 (Line)
Info : Meshing curve 94 (Line)
Info : Meshing curve 95 (Line)
Info : Meshing curve 96 (Line)
Info : Meshing curve 97 (Line)
Info : Meshing curve 98 (Line)
Info : Meshing curve 99 (Line)
Info : Meshing curve 100 (Line)
Info : Meshing curve 101 (Line)
Info : Meshing curve 102 (Line)
Info : Meshing curve 103 (Line)
Info : Meshing curve 104 (Line)
Info : Meshing curve 105 (Line)
Info : Meshing curve 106 (Line)
Info : Meshing curve 107 (Line)
sh: SMDS_MemoryLimit: command not found
Info : Meshing curve 108 (LiFailed to auto-save document 'gh4'
Steps To Reproduce1. Load gh4.fcstd
2. Run gmsh
Happens every time to me, and I've not yet found a way around it...
Additional Informationgh4.fcstd here:
https://drive.google.com/open?id=0B6KWLyPRYMb0QnMzUWdXSTRGOWs
KarenRei
2016-05-30 22:18
reporter   ~0007129
Just to make clear, it's FreeCAD that crashes.
KarenRei
2016-05-30 22:22
reporter   ~0007130
Forgot to include version info:
OS: "Fedora release 22 (Twenty Two)"
Version: 0.17.7680 (Git)
Build type: Unknown
Hash: 966ce79207da593db8a7848e23c82f4d3baad27c
Python version: 2.7.10
Qt version: 4.8.7
Coin version: 3.1.3
OCC version: 6.7.1.oce-0.16
KarenRei
2016-06-02 00:24
reporter   ~0007137
I'm pretty sure, I should add, that I think these are "out of memory" issues of some sort. But why that model should run FreeCAD out of memory is beyond me.
It was suggested earlier on the forum that the problem might be because the above model has errors. Well, this one doesn't, according to FreeCAD:
https://drive.google.com/open?id=0B6KWLyPRYMb0RUdqbGpoUllCWjg
And it crashes just the same.
2017-01-15 14:24
administrator   ~0007793
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19920
2017-02-10 05:16
administrator   ~0008260
Marking with 'Feedback' status to keep track of this ticket.
2017-03-02 16:19
administrator   ~0008519
@NormandC if and when you get a moment, do you mind testing this?
ulrich1a
2017-03-05 17:44
reporter   ~0008542
Made a test with the actual version.
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.17.10424 (Git)
Branch: Rueck6
Hash: 5c5537da737d55e77ecde65fda7d1ea6512ffe76
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.1.0
The actual version of FreeCAD does not crash at my machine. (32Gb Ram)
See also the forum thread.
berndhahnebach
2017-03-06 21:29
developer   ~0008552
The crash happend with the depreceated GMSH module. I remember the topic. The model had tons of errors. Never ever possible to make a valid FEM mesh from this data. No mesher all over the world could fix all the errors. But I must admit FreeCAD should not crash if GMHS crashes. Since there where so many errors I did not made a report at GMSH people at that time. Just tried again with FreeCADs included GMSH mesh object and it does not crash (same as last post of ulrich1a). I even tried with the old macro but it did not crash either. But may be it's not the same macro and I have not the same GMSH binary and FreeCAD has changed too.
From my point of view it can be closed.
bernd
2017-03-06 22:10
administrator   ~0008553
Per @berndhahnebach
Therefore resolving issue.
2016-05-30 22:17 KarenRei New Issue
2016-05-30 22:18 KarenRei Note Added: 0007129
2016-05-30 22:22 KarenRei Note Added: 0007130
2016-06-02 00:24 KarenRei Note Added: 0007137
2017-01-15 14:24 Kunda1 Note Added: 0007793
2017-02-10 05:16 Kunda1 Note Added: 0008260
2017-02-10 05:16 Kunda1 Status new => feedback
2017-03-02 16:19 Kunda1 Note Added: 0008519
2017-03-05 17:44 ulrich1a Note Added: 0008542
2017-03-06 21:29 berndhahnebach Note Added: 0008552
2017-03-06 22:10 Kunda1 Status feedback => resolved
2017-03-06 22:10 Kunda1 Resolution open => no change required
2017-03-06 22:10 Kunda1 Note Added: 0008553
2017-03-07 12:49 Kunda1 Assigned To => berndhahnebach
2017-03-07 12:49 Kunda1 Status resolved => closed
2017-03-07 12:49 Kunda1 Resolution no change required => unable to reproduce
