0002577ArchFeaturepublic2021-09-21 08:29
Reporteryorik Assigned Toyorik
Status closedResolutionfixed
PlatformPCOSDebianOS VersionTesting 64bit
Target Version0.20Fixed in Version0.20
Summary0002577: Support for hatch patterns
Description1. Add equivalents to all autocad hatch patterns in DrawingPatterns module
2. Support DrawingPatterns in Material Editor
3. Support the DrawingPatterns module in Draft/Arch
4. Allow to import hatch patterns from DXF files
5. Allow to export Draft objects with patterns to DXF
6. Allow to export Drawing pages with patterns to DXF
Tagshatch
Relationships
related to 0001980 new Draft better hatch Pattern presentation for planes not parallel to xy
yorik
2016-06-20 22:53
administrator   ~0007155
Qt4 doesn't support the SVG <pattern> tag that is used for hatch patterns. Qt5 will apparently support the full SVG specs, so this is postponed to after the Qt5 port
2021-09-08 14:00
administrator   ~0015917
Draft WB just got hatch pattern support:
thread: https://forum.freecad.org/viewtopic.php?f=9&t=62048
commit: c:FreeCAD:1c8b803f9e: (link)
yorik
2021-09-21 08:28
administrator   ~0015949
This is basially done, with the commit @Kunda1 mentioned above.
Related Changesets
FreeCAD: master b18981f0
2016-06-04 22:41:23
yorik
Details Diff
Added more SVG patterns + translation table - issue 0002577 Affected Issues
0002577
mod - src/Mod/Drawing/DrawingPatterns.py Diff File
FreeCAD: master 319920c1
2016-06-10 03:19:45
yorik
Details Diff
Material: allow to display Drawing Patterns in material editor - issue 0002577 Affected Issues
0002577
mod - src/Mod/Material/MaterialEditor.py Diff File
mod - src/Mod/Material/materials-editor.ui Diff File
2016-06-03 15:27 yorik New Issue
2016-06-03 15:27 yorik Status new => assigned
2016-06-03 15:27 yorik Assigned To => yorik
2016-06-03 15:27 yorik Project FreeCAD => Arch
2016-06-04 20:44 yorik Changeset attached => FreeCAD Master master b18981f0
2016-06-10 01:20 yorik Changeset attached => FreeCAD Master master 319920c1
2016-06-20 22:53 yorik Note Added: 0007155
2016-10-09 21:59 yorik Summary Support for hatch patterns => [on hold] Support for hatch patterns
2017-05-10 01:32 Kunda1 Tag Attached: hatch
2018-01-12 15:09 yorik Target Version => 0.18
2019-02-15 00:25 yorik Target Version 0.18 => 0.19
2021-02-06 06:28 abdullah Target Version => 0.20
2021-09-08 13:58 Kunda1 Relationship added related to 0001980
2021-09-08 14:00 Kunda1 Summary [on hold] Support for hatch patterns => Support for hatch patterns
2021-09-08 14:00 Kunda1 Note Added: 0015917
2021-09-08 14:01 Kunda1 Note Edited: 0015917
2021-09-21 08:28 yorik Note Added: 0015949
2021-09-21 08:29 yorik Note Edited: 0015949
2021-09-21 08:29 yorik Status assigned => closed
2021-09-21 08:29 yorik Resolution open => fixed
2021-09-21 08:29 yorik Fixed in Version => 0.20
