0002579FreeCADBugpublic2017-01-20 10:41
Reportermik Assigned To
Status closedResolutionfixed
PlatformlinuxOSubuntuOS Versionx64
Product Version0.16
Fixed in Version0.17
Summary0002579: Invalid positioning
DescriptionUsing manual placement (edit mode) doesn't play well with setting positional parameters in the placement window.
Steps To ReproduceCreate a new project. Add a cylinder from the Part menu. Now double click the cylinder in the left treeview, so that the Cylinder get surrounded with arrows and circles (i.e. toggle Edit mode). Now use your mouse to move it around, change it's rotation etc.
Now click the Placement property so that the Placement window will appear on the left. Don't change any number - just click "Apply" repeatedly and you'll see that everytime you click it, the cylinder moves a little.
In some scenarios the Cylinder's position will converge to some position nearby, but sometimes it will move away randomly.
This can get even worse if you move/rotate the Cylinder while still being in the Placement window and then click Apply.
Both behaviours are buggy, as I expect it to stand still if I just click "Apply" repeatedly.
2017-01-17 20:32
administrator   ~0007852
Forum thread: http://forum.freecad.org/viewtopic.php?f=10&t=19991
mik
2017-01-20 09:04
reporter   ~0007894
I'm no longer able to reproduce it myself, so i guess it must've been fixed in some release.
My current FreeCad:
OS: Ubuntu 16.04.1 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
2017-01-20 10:41
administrator   ~0007895
Thanks @mik for retesting and reporting.
Closing.
2016-06-07 09:51 mik New Issue
2017-01-17 20:32 Kunda1 Note Added: 0007852
2017-01-20 09:04 mik Note Added: 0007894
2017-01-20 10:41 Kunda1 Note Added: 0007895
2017-01-20 10:41 Kunda1 Status new => closed
2017-01-20 10:41 Kunda1 Resolution open => fixed
2017-01-20 10:41 Kunda1 Fixed in Version => 0.17
