| 0002588 | FreeCAD | Feature | public | 2016-06-13 08:41 | 2017-07-11 20:05 |
| Reporter | AdamJelinek | Assigned To | |||
| OS | Windows 7 x64 | ||||
| Summary | 0002588: Frame Rate unreadable | ||||
| Description | If framerate counter is enabled (preferences - Display - 3D View - Show counter of frames per seconds ), it is not readable due to its constantly moving position. If the model is being rotated, then the counter flows to left and right accordingly to number of decimals and therefore is not readable. Its position should be fixed to decimal pointer. Also the time counter and framerate counter could be on 2 lines. | ||||
| Steps To Reproduce | Enable the framerate counter and move with part. | ||||
@normandc do you mind weighing in on this ? |
I can't reproduce this issue. The counter has always 1 decimal, never more, and the counter is fixed in the same location. O/T I really don't understand the purpose of a frame rate counter in a CAD program. This is not a First-Person Shooter. <rolleyes> OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6707 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
NormandC was unable to reproduce. Resolving. |
| 2016-06-13 08:41 | AdamJelinek | New Issue | |
| 2016-06-13 08:41 | AdamJelinek | File Added: Bez názvu.jpg | |
| 2017-01-24 00:33 | Kunda1 | File Deleted: Bez názvu.jpg | |
| 2017-01-24 00:33 | Kunda1 | File Added: Bez názvu.jpg | |
| 2017-03-20 21:32 | Kunda1 | Note Added: 0008666 | |
| 2017-03-20 21:33 | Kunda1 | Tag Attached: #pending | |
| 2017-03-21 02:07 | normandc | Note Added: 0008672 | |
| 2017-03-21 04:12 | Kunda1 | Status | new => resolved |
| 2017-03-21 04:12 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-03-21 04:12 | Kunda1 | Note Added: 0008674 | |
| 2017-04-28 19:30 | Kunda1 | Status | resolved => closed |
| 2017-07-11 20:05 | Kunda1 | Tag Detached: #pending |
