| 0002601 | PartDesign | Bug | public | 2016-06-23 12:33 | 2017-07-11 20:09 |
| Reporter | wrafal | Assigned To | |||
| Platform | Linux | OS | Ubuntu | OS Version | 14.04 LTS |
| Summary | 0002601: Changing object Placement params do not update it on view | ||||
| Description | I tried to cutout 2 cylinders from square and noticed that when I am changing parameters like Radios, height or angle of cylinder it immediately updates the view (so changes can be seen) but when changing Placement parameters such az Translation, Center or Location object is not moving or rotating. | ||||
| Steps To Reproduce | 1. Place any object from Part design WB 2. Change Placement parameters 3. View is not updater immediately See attached movie. | ||||
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20266 |
According to @chrisb https://forum.freecadweb.org/viewtopic.php?f=10&t=20266&p=156263#p156263 > No problem here, even when I am in translation mode as the reporter (probably by mistake) was. Ticket can be closed. |
The cylinder shape is edited by two functions at the same time which causes a mess. In 0.17 the Transform command (by double-click or context-menu) opens a task panel and thus the placement editor cannot be opened at the same time. So, this already fixes the issue. |
| 2016-06-23 12:33 | wrafal | New Issue | |
| 2016-06-23 12:33 | wrafal | File Added: freecad_updating_objects.mp4 | |
| 2017-01-27 03:02 | Kunda1 | Note Added: 0008012 | |
| 2017-01-27 03:02 | Kunda1 | Status | new => feedback |
| 2017-01-27 03:02 | Kunda1 | Tag Attached: #pending | |
| 2017-01-27 12:46 | Kunda1 | Note Added: 0008024 | |
| 2017-01-27 12:46 | Kunda1 | Status | feedback => resolved |
| 2017-01-27 12:46 | Kunda1 | Fixed in Version | => 0.16 |
| 2017-01-27 12:46 | Kunda1 | Resolution | open => fixed |
| 2017-01-27 12:46 | Kunda1 | Assigned To | => Kunda1 |
| 2017-01-27 12:46 | Kunda1 | Assigned To | Kunda1 => |
| 2017-01-27 12:46 | Kunda1 | Fixed in Version | 0.16 => |
| 2017-01-31 18:31 | wmayer | Note Added: 0008134 | |
| 2017-01-31 18:31 | wmayer | Status | resolved => closed |
| 2017-01-31 18:31 | wmayer | Fixed in Version | => 0.17 |
| 2017-07-11 20:09 | Kunda1 | Tag Detached: #pending |
