0002603PartDesignBugpublic2017-03-08 19:11
Reporterderei Assigned ToKunda1
PlatformPCOSWindows7 SP1OS Versionx64
Summary0002603: Model completely disappeared when attempted to do a Fillet operation
DescriptionAfter attempting to add a Fillet Operation (1mm) on the Pad002 (attached file), to the inner side, the model completely disappeared.
I understand that fillet maybe was not possibly to be processed due to the adjacent geometry, but having the entire model disappear and with no way to have it back, is a bit hardcore.
normandc
2016-07-03 15:35
manager   ~0007168
If I do a zoom "Fit all", I see your model just fine.
You do not give enough information. On which edge is the fillet failing?
And please report your problems to the forum before creating bug reports, so experienced users can confirm or not if there is indeed a bug and ensure the quality of the bugs reported here.
One other thing: all your features are built on top one another, which means your file contains a single part, which is fine. But all your features are visible, which is not: always leave the last feature visible only, and hide the others, otherwise you run the risk of forking your model.
2017-01-17 04:40
administrator   ~0007832
@derei please respond to 0002603:0007168
2017-01-25 12:36
administrator
2017-01-25 12:36
administrator
Model Disappeared.FCStd (59,350 bytes)
2017-01-25 12:38
administrator   ~0007980
@derei plz respond to the above as well as adding the content of Help > About FreeCAD > Copy to clipboard
2017-01-29 15:22
administrator   ~0008083
By reading normandc's response, this looks like user-error. Unfortunately, there has been no response from OP.
Resolving as 'no change required'.
2016-06-26 13:26 derei New Issue
2016-06-26 13:26 derei File Added: Model Disappeared.7z
2016-07-03 15:35 normandc Note Added: 0007168
2017-01-17 04:40 Kunda1 Note Added: 0007832
2017-01-17 04:40 Kunda1 Status new => feedback
2017-01-25 12:36 Kunda1 File Added: 2016-06-26_142310.png
2017-01-25 12:36 Kunda1 File Added: Model Disappeared.FCStd
2017-01-25 12:37 Kunda1 File Deleted: Model Disappeared.7z
2017-01-25 12:38 Kunda1 Note Added: 0007980
2017-01-29 15:22 Kunda1 Note Added: 0008083
2017-01-29 15:22 Kunda1 Status feedback => resolved
2017-01-29 15:22 Kunda1 Resolution open => no change required
2017-01-29 15:22 Kunda1 Assigned To => Kunda1
2017-03-08 19:11 kkremitzki Status resolved => closed
