| 0002651 | Sketcher | Bug | public | 2016-07-29 14:17 | 2017-02-15 06:16 |
| Reporter | maiden | Assigned To | kkremitzki | ||
| Priority | normal | Severity | major | Reproducibility | sometimes |
| Platform | Linux | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0002651: crash on save, not able to delete constraint on point with index 0 | ||||
| Description | FreeCAD 0.17, Libs: 0.17R8046 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Fasteners workbench Loaded Not able to delete a constraint on point with the given index: 0 Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Failed to add box: Both points are equal Unhandled exception in ViewProvider::eventCallback: Constraint has invalid indexes *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 100000011 | ||||
| Steps To Reproduce | gets this sometimes when i save, can not provide an easy step by step guide as the latest progress is lost when it crashes. | ||||
| Additional Information | running latest git | ||||
If you can't provide a reproducible step-by-step process to get this crash, or a file, how do you expect the developers to solve it? Please have a look at this wiki page on debugging: http://www.freecadweb.org/wiki/index.php?title=Debugging#Generating_a_Backtrace |
If no further information is provided, this bug report will be closed. |
per @normandc > If no further information is provided, this bug report will be closed. Resolving ticket unless OP decides to supply details or devs think differently. |
| 2016-07-29 14:17 | maiden | New Issue | |
| 2016-07-31 21:37 | normandc | Note Added: 0007231 | |
| 2016-07-31 21:38 | normandc | Note Edited: 0007231 | |
| 2016-10-15 19:51 | normandc | Severity | crash => major |
| 2016-10-15 19:51 | normandc | Status | new => feedback |
| 2016-10-15 19:52 | normandc | Note Added: 0007369 | |
| 2017-01-16 08:03 | Kunda1 | Note Added: 0007806 | |
| 2017-01-16 08:03 | Kunda1 | Status | feedback => resolved |
| 2017-01-16 08:03 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-01-16 08:03 | Kunda1 | Assigned To | => Kunda1 |
| 2017-01-16 08:03 | Kunda1 | Assigned To | Kunda1 => |
| 2017-02-15 06:16 | kkremitzki | Status | resolved => closed |
| 2017-02-15 06:16 | kkremitzki | Assigned To | => kkremitzki |
