| 0002653 | FreeCAD | Feature | public | 2016-08-04 11:48 | 2018-08-26 18:05 |
| Reporter | trampas | Assigned To | Kunda1 | ||
| Priority | high | Severity | tweak | Reproducibility | always |
| Summary | 0002653: Sketch constraints and lines | ||||
| Description | The snaps to line ends is so hard to make happen I often place lines that are not connected. It takes forever to find the one that is .01 microns off. See 0003085 What would be nice is to have lines change colors if they are fully constrained, or maybe have points change colors if they are matched. See 0000704:0009406 Additionally it would be nice to have the CTRL key during line operation increase the snap active area such that it is easy to match points. See 0003086 Also it would be nice to have a line chain option where next starting point of line is last placed point of previous line, for example place a line while holding down a key... See 0003087 | ||||
| duplicate of | 0003087 | closed | chrisb | FreeCAD | have a line chain option where next starting point of line is last placed point of previous line |
| duplicate of | 0003086 | new | Sketcher | CTRL key during line operation increase the snap active area such that it is easy to match points | |
| duplicate of | 0003085 | closed | FreeCAD | The snaps-to-line-ends is so hard to make happen |
This report is poorly made because it includes 4 totally different feature requests. Did you know that you can use the Polyline tool instead of the line tool? I seldom use the Line tool. >What would be nice is to have lines change colors if they are fully constrained There are 3 existing feature requests for this. But this is hard to implement. 0000704 |
What should we do with this ticket? Split it in to separate feature requests ? |
@trampas please open a forum ticket next time to discuss each Feature Request with the community. Many decisions happen on the forum and feedback will be offered. Also Shen opening a ticket please limit one issue per ticket. It makes it easier to Triage. I've split your ticket in the meantime. Thanks for your comprehension. |
| 2016-08-04 11:48 | trampas | New Issue | |
| 2016-08-07 17:04 | normandc | Note Added: 0007256 | |
| 2017-01-13 00:07 | Kunda1 | Note Added: 0007697 | |
| 2017-01-13 00:07 | Kunda1 | Tag Attached: split ticket | |
| 2017-06-16 11:55 | Kunda1 | Description Updated | |
| 2017-06-16 12:16 | Kunda1 | Description Updated | |
| 2017-06-16 12:21 | Kunda1 | Relationship added | duplicate of 0003087 |
| 2017-06-16 12:22 | Kunda1 | Relationship added | duplicate of 0003086 |
| 2017-06-16 12:23 | Kunda1 | Relationship added | duplicate of 0003085 |
| 2017-06-16 12:29 | Kunda1 | Assigned To | => Kunda1 |
| 2017-06-16 12:29 | Kunda1 | Status | new => closed |
| 2017-06-16 12:29 | Kunda1 | Resolution | open => duplicate |
| 2017-06-16 12:29 | Kunda1 | Note Added: 0009407 | |
| 2017-07-04 19:54 | Kunda1 | Description Updated | |
| 2018-08-26 18:05 | Kunda1 | Tag Detached: split ticket |
