| 0002665 | PartDesign | Bug | public | 2016-08-09 07:26 | 2017-08-21 14:23 |
| Reporter | smooker | Assigned To | |||
| Priority | high | Severity | crash | Reproducibility | have not tried |
| Platform | AMD64 | OS | Debian | OS Version | stretch/sid |
| Summary | 0002665: Crash trying to create a pocket from an unattached sketch | ||||
| Description | Trying to make a pocket causes: [smooker@sh2 ~/src/freecad-projects/proba]$ FreeCAD ./proba.fcstd FreeCAD 0.17, Libs: 0.17R8161 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Can't find Origin for "Body" Can't find Origin for "Body" Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. Gui::DocumentItem::slotChangedObject(): Group references unknown object. | ||||
*** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 1c0 |
Please read the bug reporting guidelines. http://forum.freecadweb.org/viewtopic.php?f=3&t=5236 Unless you post a reproducible method for the crash, a file or any other relevant info, this bug report will be closed because it is utterly useless as it is. |
I was able to reproduce the crash twice, but I couldn't find a way to get it reliable. The point is that the behaviour has changed when trying to create a pocket from an unattached sketch. In v0.16 and older it pops up a dialog that the sketch has no support face and does nothing further. In v0.17 it first opens the task panel (but the 3d view becomes empty) and after pressing the OK button the above error message appears. Now I was able to get the crash: * open two documents * create a sketch on the one * while the task dialog is open switch to the other document * closing the task panel now doesn't destroy the invalid pocket feature Now after some wild clicking it crashed for me two times but wasn't able to locate the reason. |
This ticket needs to be renamed to reflect the problem. |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=20519 |
@normandc please check when you have a moment? Thanks! |
@normandc re-pinging JIC you didn't see the above ping. |
I can't provide any help on this. wmayer is the one who could reproduce the issue. |
@kunda1 where is this file? proba.fcstd I have tried also Werner's instructions without being able to reproduce. Maybe the reporter could evaluate if this has been solved or not and provide a way to reproduce it if not solved? |
@smooker please try to reproduce with latest dev revision. @wmayer perhaps you can as well? |
@wmayer please weigh in at your earliest convenience..thanks! |
Can't reproduce it any more. |
| 2016-08-09 07:26 | smooker | New Issue | |
| 2016-08-09 07:28 | smooker | Note Added: 0007257 | |
| 2016-08-14 20:06 | normandc | Note Added: 0007272 | |
| 2016-08-15 08:02 | wmayer | Note Added: 0007274 | |
| 2016-08-15 08:02 | wmayer | Status | new => confirmed |
| 2017-01-10 13:03 | Kunda1 | Note Added: 0007598 | |
| 2017-01-11 19:41 | Kunda1 | Summary | Crash => Crash trying to create a pocket from an unattached sketch |
| 2017-02-07 02:34 | Kunda1 | Note Added: 0008228 | |
| 2017-02-20 22:02 | Kunda1 | Note Added: 0008389 | |
| 2017-05-02 13:11 | Kunda1 | Product Version | => 0.17 |
| 2017-05-02 13:11 | Kunda1 | Target Version | => 0.17 |
| 2017-05-02 13:12 | Kunda1 | Note Added: 0008851 | |
| 2017-05-03 00:52 | normandc | Note Added: 0008877 | |
| 2017-05-24 22:53 | abdullah | Note Added: 0009129 | |
| 2017-05-24 23:14 | Kunda1 | Note Added: 0009130 | |
| 2017-05-24 23:14 | Kunda1 | Status | confirmed => feedback |
| 2017-08-14 00:07 | Kunda1 | Note Added: 0009921 | |
| 2017-08-21 14:23 | wmayer | Status | feedback => closed |
| 2017-08-21 14:23 | wmayer | Resolution | open => unable to reproduce |
| 2017-08-21 14:23 | wmayer | Note Added: 0009981 |
