| 0002670 | FreeCAD | Bug | public | 2016-08-14 08:01 | 2017-10-16 10:07 |
| Reporter | worldmaker | Assigned To | |||
| OS | Windows 7 | ||||
| Summary | 0002670: Deprecated and inactive Mesh Boolean Python commands still permitted | ||||
| Description | Since FreeCAD v0.14, native Mesh Boolean operations were replaced with OpenSCAD algorithms thus require third-party open source program OpenSCAD to be installed. When calling Mesh Booleans from the GUI, if the path to OpenSCAD executable is not found, an error message appears. But deprecated python commands do not warn the user, and an empty or broken mesh is created in the document. | ||||
| Steps To Reproduce | 1. Open FreeCAD 2. Press the "create new document" button 3. enter the python codes:
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7745 (Git) Build type: Release Branch: master Hash: 79dcdfbc782e24bb34db882143af7ce8ebd237bd Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | Mesh | ||||
Since some time (0.15.4671 I believe, maybe sooner) mesh Booleans are managed by OpenSCAD. Therefore you must install OpenSCAD. The python code will be different. It will be something like this (output from doing it through the GUI):
The real bug here may be that "m3 = m1.intersect(m2)" does not produce a warning/error. |
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19905 |
@normandc please advise. Shall we open a new ticket based on:
If so do you mind opening it since I'm not sure the verbiage or the problem exactly. Thanks! |
Ping @normandc |
@NormandC just making sure we don't lose track. Do you mind following up? Thanks! |
Changed report summary and description to what is the real issue. The following wiki page also still provides obsolete information: https://www.freecadweb.org/wiki/Mesh_Scripting The following wiki pages don't mention the OpenSCAD prerequisite: https://www.freecadweb.org/wiki/Mesh_Union https://www.freecadweb.org/wiki/Mesh_Intersection https://www.freecadweb.org/wiki/Mesh_Difference |
@keithsloan52 do you have any time to put this on your 'plate' ? |
@Kunda1 Sorry, not at the moment. I have just started an Open University course and the power supply on my Linux machine died. As it was 32bit and an old Graphics card I have bought a new one, but it will take me some time to setup and get back to the stage where I can do development type work |
This is not a bug at all. Why should the (low-level) Python functions raise a warning when it's used? It's simply up to the user to use the API of OpenSCAD to perform reliably boolean operations and this he can easily find out by macro recording. |
| 2016-08-14 08:01 | worldmaker | New Issue | |
| 2016-08-14 08:01 | worldmaker | File Added: bug2.png | |
| 2016-08-14 19:59 | normandc | Note Added: 0007270 | |
| 2017-01-15 01:22 | Kunda1 | Tag Attached: Mesh | |
| 2017-01-15 01:24 | Kunda1 | Note Added: 0007775 | |
| 2017-01-24 22:20 | Kunda1 | Status | new => feedback |
| 2017-03-02 12:45 | Kunda1 | Note Added: 0008510 | |
| 2017-03-28 19:25 | Kunda1 | Note Edited: 0008510 | |
| 2017-05-10 11:57 | Kunda1 | Note Added: 0008932 | |
| 2017-06-28 14:29 | Kunda1 | Note Added: 0009578 | |
| 2017-07-01 05:45 | normandc | Status | feedback => confirmed |
| 2017-07-01 05:45 | normandc | Product Version | 0.16 => 0.17 |
| 2017-07-01 05:45 | normandc | Summary | Bad boolean operations on meshes => Deprecated and inactive Mesh Boolean Python commands still permitted |
| 2017-07-01 05:45 | normandc | Description Updated | |
| 2017-07-01 05:45 | normandc | Note Added: 0009626 | |
| 2017-09-25 13:21 | Kunda1 | Target Version | => 0.17 |
| 2017-10-10 19:09 | Kunda1 | Note Added: 0010285 | |
| 2017-10-10 19:10 | Kunda1 | Steps to Reproduce Updated | |
| 2017-10-10 19:11 | Kunda1 | Note Edited: 0007270 | |
| 2017-10-10 21:30 | keithsloan52 | Note Added: 0010286 | |
| 2017-10-16 10:07 | wmayer | Status | confirmed => closed |
| 2017-10-16 10:07 | wmayer | Resolution | open => won't fix |
| 2017-10-16 10:07 | wmayer | Note Added: 0010298 |
