0002671FreeCADBugpublic2017-07-23 20:56
ReporterSyranolic Assigned Toeivindkvedalen
Status closedResolutionfixed
OS VersionWindows 7 x64
Product Version0.16
Fixed in Version0.17
Summary0002671: Operation properties without units in spreadsheet
DescriptionThe "value" of the "offset" operation and the "base" vector of the "mirror" operation have no unit and can't accept spreadsheets values with a unit. There may be more operations affected, I only use a few.
Additional InformationOS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0
Python version: 2.7.8
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
Tagsspreadsheet, units
Syranolic
2016-08-14 15:07
reporter   ~0007269
http://forum.freecad.org/viewtopic.php?f=3&t=16976
2017-03-09 13:09
administrator   ~0008589
@eivindkvedalen can this ticket be assigned to you ?
mjscosta
2017-07-18 15:24
reporter   ~0009772
Hi, not sure, but I think I found this same/simillar problem.
1- I've created a spreadsheet, added some value with alias (val1_mm). The value has no unit, but the display unit is mm.
2- Added a Contraints.contraint1 (in mm).
3- Added a second constraint using the expression "Contraints.contraint1 + Spreadsheet.var1_mm", got the error "Incompatible unit for + operator".
4- Added units to the value, in the spreadsheet and the no error.
5- If using operator "*", the inverse happens. No error when there is no unit, and there is an error "Incompatible unit for * operator" when there is a unit in the spreadsheet value.
Please check thread, for additional data:
https://forum.freecad.org/viewtopic.php?f=3&t=16976&p=183033#p183033
OS: Ubuntu 16.04.2 LTS
Version: 0.17.11580 (Git)
Build type: None
Hash: aa07c777453258edf9fed304cf82bcfeb8bdea95
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 7.1.0
2017-07-18 15:26
administrator   ~0009773
@mjscosta thank you. Do you mind also posting this to the forum thread mentioned in 0002671:0007269 ?
mjscosta
2017-07-19 08:42
reporter   ~0009780
@Kunda1, done.
Admin Edit: specifically https://forum.freecad.org/viewtopic.php?f=3&t=16976&start=10#p183033
2017-07-23 16:00
administrator   ~0009797
@eivindkvedalen submitted FreeCAD Pull Request 894 as a fix.
2017-07-23 20:54
administrator   ~0009800
Merged in c:FreeCAD:55e0e6c00dfbc3569a80c602a96906a0c2c50cd4:
2016-08-14 15:05 Syranolic New Issue
2016-08-14 15:07 Syranolic Note Added: 0007269
2017-01-19 14:28 Kunda1 Tag Attached: spreadsheet
2017-01-19 14:28 Kunda1 Tag Attached: units
2017-03-09 13:08 Kunda1 Assigned To => Kunda1
2017-03-09 13:08 Kunda1 Status new => assigned
2017-03-09 13:08 Kunda1 Assigned To Kunda1 =>
2017-03-09 13:09 Kunda1 Status assigned => confirmed
2017-03-09 13:09 Kunda1 Note Added: 0008589
2017-03-09 13:10 Kunda1 Summary Operation properties without units => Operation properties without units in spreadsheet
2017-07-16 11:36 Kunda1 Assigned To => eivindkvedalen
2017-07-16 11:36 Kunda1 Status confirmed => assigned
2017-07-18 15:24 mjscosta Note Added: 0009772
2017-07-18 15:26 Kunda1 Note Added: 0009773
2017-07-19 08:42 mjscosta Note Edited: 0009772
2017-07-19 08:42 mjscosta Note Added: 0009780
2017-07-19 10:52 Kunda1 Note Edited: 0009780
2017-07-23 16:00 Kunda1 Note Added: 0009797
2017-07-23 20:54 Kunda1 Note Added: 0009800
2017-07-23 20:54 Kunda1 Status assigned => closed
2017-07-23 20:54 Kunda1 Resolution open => fixed
2017-07-23 20:54 Kunda1 Fixed in Version => 0.17
2017-07-23 20:56 Kunda1 Note Edited: 0009800
