| 0002690 | Draft | Bug | public | 2016-09-04 17:34 | 2017-02-20 00:33 |
| Reporter | bgoodr | Assigned To | |||
| Platform | Ubuntu Linux | OS | Ubuntu 16.04.1 LTS | OS Version | Ubuntu 16.04.1 |
| Summary | 0002690: Regression: Mouse snapping to vertices is broken in 0.17.8353 | ||||
| Description | Mouse snapping to vertices does not work on version 0.17, but does work in version 0.16. Stable 0.16 build I used that works is: OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6703 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40 Python version: 2.7.11+ Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 Unstable 0.17 build that does not work is: OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8353 (Git) Build type: None Branch: master Hash: 04aa24ec00bcd05442b1b345757175a4459fc553 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Steps To Reproduce | 1. Start freecad-daily 2. Create a new design using Part design 3. Switch to Draft workbench 4. Add a rectangle somewhere (not on grid) 5. Set workplane to that rectangle 6. Start a line object (L I) 7. Move mouse cursor over to a vertex of the added rectangle 8. Mouse should change to show the vertex image but does not. It does on 0.16 stable build. See annotated screenshot: http://i.imgur.com/7SpIZhC.png | ||||
| Tags | snap | ||||
I cannot reproduce this problem, for me everything works normally... |
Are you sure the "snap to working plane" option is not enabled? That might cause your actual snap point to be quite far from your object... |
I apologize for the late reply. I tested this again using today's freecad and I can reproduce it easily. I confirmed that I am definitely on the workplane of the rectangle object and the mouse cursor does not change as I expect it to when the mouse is moved close to a corner vertex on the rectangle I just added. I have 0.16 installed and it does change. Below is the part of the installation log indicating the version of 0.17 I am using of freecad-daily: Selecting previously unselected package freecad-daily. Preparing to unpack .../freecad-daily_0.17~alpha1+git201609212031~ubuntu16.04.1_amd64.deb ... Unpacking freecad-daily (0.17~alpha1+git201609212031~ubuntu16.04.1) ... Selecting previously unselected package freecad-daily-doc. Preparing to unpack .../freecad-daily-doc_0.17~alpha1+git201609212031~ubuntu16.04.1_all.deb ... Unpacking freecad-daily-doc (0.17~alpha1+git201609212031~ubuntu16.04.1) ... What else can I do to demonstrate this bug? |
Another thing I noticed on version 0.17: Moving the cursor to the midpoint of an edge of the rectangle should cause the mouse cursor to change to something that indicates that the mouse is on the midpoint, because I have snapping to midpoint selected. But it does not. So it seems that maybe one or more snapping behaviors are not working on this build for some reason. |
This is the 0.17 version I'm using for my recent posts above: OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8469 (Git) Build type: None Branch: master Hash: 40c79f18e4d63c86fa865c43f0276ee1cff00abb Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
@bgoodr please create a thread in the forum to generate further discussion about the issue. Thx. |
@Kunda1 I have posted it into the forum at https://forum.freecadweb.org/viewtopic.php?f=3&t=20627#p159459 |
@bgoodr you have a response from @normandc in https://forum.freecadweb.org/viewtopic.php?f=3&t=20627#p159548 |
@bgoodr > bgoodr wrote: > Mouse snapping to vertices is broken in 0.17.8353 in September you updated to 0.17.8469 This bug report is from last year. Can you confirm that your freecad-daily package is up to date. The latest development revision number is over 10 000. |
As reported just now on the forum thread, I have verified this is now working with this build: |
Thanks for the follow up. Closing ticket as fixed |
| 2016-09-04 17:34 | bgoodr | New Issue | |
| 2016-09-04 18:56 | yorik | Note Added: 0007303 | |
| 2016-09-11 19:43 | yorik | Note Added: 0007314 | |
| 2016-09-25 17:49 | bgoodr | Note Added: 0007332 | |
| 2016-09-25 17:52 | bgoodr | Note Added: 0007333 | |
| 2016-09-25 17:56 | bgoodr | Note Added: 0007334 | |
| 2017-01-31 18:48 | Kunda1 | File Added: 7SpIZhC.png | |
| 2017-01-31 18:49 | Kunda1 | Product Version | => 0.17 |
| 2017-01-31 18:50 | Kunda1 | Note Added: 0008136 | |
| 2017-01-31 18:50 | Kunda1 | Status | new => feedback |
| 2017-01-31 18:50 | Kunda1 | Tag Attached: snap | |
| 2017-02-12 07:26 | bgoodr | Note Added: 0008275 | |
| 2017-02-12 07:26 | bgoodr | Status | feedback => new |
| 2017-02-15 19:32 | Kunda1 | Summary | Mouse snapping to vertices is broken in 0.17.8353 => Regression: Mouse snapping to vertices is broken in 0.17.8353 |
| 2017-02-15 19:34 | Kunda1 | Note Added: 0008313 | |
| 2017-02-15 19:34 | Kunda1 | Status | new => feedback |
| 2017-02-18 12:13 | Kunda1 | Note Added: 0008346 | |
| 2017-02-20 00:02 | bgoodr | Note Added: 0008376 | |
| 2017-02-20 00:02 | bgoodr | Status | feedback => new |
| 2017-02-20 00:33 | Kunda1 | Status | new => closed |
| 2017-02-20 00:33 | Kunda1 | Resolution | open => fixed |
| 2017-02-20 00:33 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-02-20 00:33 | Kunda1 | Note Added: 0008377 |
