| 0002698 | File formats | General | public | 2016-09-15 16:35 | 2017-05-01 17:56 |
| Reporter | SMusche | Assigned To | wmayer | ||
| Platform | FreeCAD 0.16 6704 | OS | Windows 7 32-bit | ||
| Summary | 0002698: Exported STEP-File contains surplus PRODUCTS | ||||
| Description | In FreeCAD 0.15 the exported STEP-file includes only the objects which were selected for export before starting the export dialog. In 0.16 the STEP-file contains a "PRODUCT('ASSEMBLY','ASSEMBLY','',(0000008));" in addition to the preselected objects. This additional product 'ASSEMBLY' causes trouble, when importing the 0.16 STEP file into other applications, especially when they expect the STEP file to contain only one PRODUCT. I checked customer STEP-files I received during last months, which were created with commercial systems (e. g. PRO/ENGINEER) and they did only contain the one PRODUCT which they were supposed to contain. | ||||
| Steps To Reproduce | With the same FCStd-file start the export dialog in 0.15 and 0.16 and create two STEP files. In the 0.16 STEP file you find the a. m. product 'ASSEMBLY' added whereas in 0.15 STEP file you only find the objects you marked for export. | ||||
| Additional Information | As a work-around I reinstalled 0.15 and use this export to STEP after finishing my work in 0.16. | ||||
| Tags | STEP | ||||
OP, please: 0) if possible, test on latest trunk and see if you get the same results 1) attach an example file to the ticket 2) post the Help > About FreeCAD > Copy to clipboard (of both your v0.15 and v0.16) 3) open a forum thread and bidirectionally link ticket <=> thread |
ad 0) I tested on 0-17_9798 today open 'Demo_Step_Export.FCStd'; highlight 'Halter'; File-Export to step Resulting file 'Demo_Step_Export_0-17_9798.step' has two lines with 'PRODUCT(' in it: line 20: 0000007 = PRODUCT('ASSEMBLY','ASSEMBLY','',(0000008)) line 3963: 0003369 = PRODUCT('Halter','Halter','',(0003370)); attached find screenshot of error connectd to 0.17 step file: 'Fehler 316 Die STEP-Datei besteht aus mehreren Einzelteilen' -> 'Error 316 The STEP-file consists of more than one parts' The 0.16 step file is processed without error ad 1) see file 'Demo_Step_Export.FCStd' ad 2) I run 0.15, 0.16, 0.17 in parallel ----- OS: Windows 7 Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.15.4671 (Git) Branch: releases/FreeCAD-0-15 Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 ----- OS: Windows 7 Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.16.6706 (Git) Build type: Release Branch: releases/FreeCAD-0-16 Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 ----- OS: Windows 7 Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.17.9798 (Git) Build type: Release Branch: master Hash: fdd34efa4356cfe6d83230a333526023356e98e3 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.0.0 ----- ad 3) Ongoing |
Forum link: https://forum.freecadweb.org/viewtopic.php?f=3&t=20455 |
FreeCAD: master 850bba79 2017-02-04 10:34:55 Details Diff |
prework for issue 0002698 |
Affected Issues 0002698 |
| mod - src/Mod/Import/App/ImportOCAF.cpp | Diff File | ||
FreeCAD: master 7901cf7a 2017-03-26 16:29:27 Details Diff |
issue 0002698: Exported STEP-File contains surplus PRODUCTS |
| mod - src/Mod/Import/App/AppImportPy.cpp | Diff File | ||
| mod - src/Mod/Import/App/ImportOCAF.h | Diff File | ||
| mod - src/Mod/Import/Gui/AppImportGuiPy.cpp | Diff File | ||
FreeCAD: releases/FreeCAD-0-16 2228a0fd 2017-04-30 17:29:54 Details Diff |
| 2016-09-15 16:35 | SMusche | New Issue | |
| 2017-01-10 13:01 | Kunda1 | Tag Attached: STEP | |
| 2017-02-02 17:53 | Kunda1 | Note Added: 0008177 | |
| 2017-02-02 17:53 | Kunda1 | Status | new => feedback |
| 2017-02-03 13:21 | SMusche | File Added: Demo_Step_Export.FCStd | |
| 2017-02-03 13:22 | SMusche | File Added: Demo_Step_Export_0-17_9798.step | |
| 2017-02-03 13:23 | SMusche | File Added: Demo_Step_Export_0-15_4671.step | |
| 2017-02-03 14:02 | SMusche | File Added: Error_Step_Import.jpg | |
| 2017-02-03 14:03 | SMusche | Note Added: 0008193 | |
| 2017-02-03 14:03 | SMusche | Status | feedback => new |
| 2017-02-03 14:31 | SMusche | Note Edited: 0008193 | |
| 2017-02-03 18:01 | wmayer | Status | new => confirmed |
| 2017-02-04 10:35 | wmayer | Changeset attached | => FreeCAD Master master 850bba79 |
| 2017-02-04 17:10 | wmayer | Note Added: 0008212 | |
| 2017-03-26 16:30 | wmayer | Changeset attached | => FreeCAD master 7901cf7a |
| 2017-03-26 16:30 | wmayer | Assigned To | => wmayer |
| 2017-03-26 16:30 | wmayer | Status | confirmed => closed |
| 2017-03-26 16:30 | wmayer | Resolution | open => fixed |
| 2017-05-01 17:56 | Kunda1 | Changeset attached | => FreeCAD releases/FreeCAD-0-16 2228a0fd |
