0002699FreeCADBugpublic2016-09-19 18:35
ReporterDeepSOIC Assigned ToDeepSOIC
Status closedResolutionfixed
Product Version0.17
Target Version0.17
Summary0002699: Part Offset2D makes direction of Extrude unstable
DescriptionWhen Part Extrude along normal is applied to Part Offset2D, the direction of extrusion changes after saving/reloading a document, or copying the shape.
Steps To Reproduce1. Sketch an ellipse.
2. Part 2D offset it (leave default values)
3. Part Extrude the offset. Leave defaults. Normal direction is +Z.
4. Draft clone the Offset2D.
5. Part Extrude the clone. Extrusion direction is -Z.
OR
1. Sketch ellipse.
2. Part 2D offset.
-> Extrusion goes up (+Z)
4. Delete Extrude.
5. Save project, and reopen it.
6. Part Extrude the offset.
-> Extrusion goes downwards (-Z).
7. Force recompute.
-> Extrusion direction changes to upwards (+Z).
Additional InformationOS: Windows 10
Version: 0.17.8361 (Git)
Branch: DeepSOIC10
Hash: 4ac7673e543274bcae856872033a114c7b60481b
Python version: 2.7.8
Qt version: 4.8.7
OCC version: 7.0.0
>>> App.ActiveDocument.Offset2D.Shape.Orientation
'Forward'
>>> sh = App.ActiveDocument.Offset2D.Shape
>>> Part.Face(sh).Surface.Axis
Vector (0.0, 0.0, 1.0)
>>> Part.Face(sh.copy()).Surface.Axis
Vector (-0.0, -0.0, -1.0)
Seems like there is some volatile reversedness in OCC offset result, that goes away upon copying, or saving to brep then loading...
forum thread:
"Part Offset2D, Draft Clone and Extrude direction weirdness"
http://forum.freecad.org/viewtopic.php?f=3&t=17449
Relationships
related to 0002700 assigned Part Part Offset2D fill offset problems
DeepSOIC
2016-09-16 19:00
developer
extrude-clone-offset-ellipse.FCStd (Attachment missing)
Related Changesets
FreeCAD: master 47c745f2
2016-09-18 17:45:04
DeepSOIC
Details Diff
Part: Offset2D: fix save-load instability
Fixes 0002699
It was found out that when direction of normal found by FindPlane
depends on if we are using result of offset directly, or after copying.
The fix (workaround) is to copy offset result inside offset routine, so
that no unstable behavior makes its way to the user.
Affected Issues
0002699
mod - src/Mod/Part/App/TopoShape.cpp Diff File
FreeCAD: master c866df1d
2016-09-19 20:34:51
yorik
Committer: GitHub Details Diff
Merge pull request 0000285 from DeepSOIC/PartOffset2D_fix1
Part: Offset2D: fix save-load instability (bug 0002699)
Affected Issues
0002699
2016-09-16 19:00 DeepSOIC New Issue
2016-09-16 19:00 DeepSOIC Status new => assigned
2016-09-16 19:00 DeepSOIC Assigned To => DeepSOIC
2016-09-16 19:00 DeepSOIC File Added: extrude-clone-offset-ellipse.FCStd
2016-09-16 19:07 DeepSOIC Relationship added related to 0002700
2016-09-19 18:35 DeepSOIC Changeset attached => FreeCAD Master master 47c745f2
2016-09-19 18:35 yorik Changeset attached => FreeCAD Master master c866df1d
2016-09-19 18:35 DeepSOIC Status assigned => closed
2016-09-19 18:35 DeepSOIC Resolution open => fixed
