| 0002703 | PartDesign | Feature | public | 2016-09-18 16:03 | 2019-09-11 19:34 |
| Reporter | nokian | Assigned To | wmayer | ||
| Summary | 0002703: Add setting to disable automatic workbench switching | ||||
| Description | When I rightclick on a "Body" Item in the model tree and click "Toggle active body" FreeCAD automatically switches to the "PartDesign" (Next) - Workbench and to the "Tasks" view. This behaviour is not always useful when using Custom Workbenches. http://forum.freecadweb.org/viewtopic.php?p=137942 | ||||
| Steps To Reproduce | 1. In PartDesign Next press "Create a new body and make it active" TWO times 2. Switch to any other workbench. 3. Right-Click on the inactive Body in the model tree 4. Choose "Toggle Active Body" | ||||
| Additional Information | OS: Linux Version: 0.17.8448 (Git) Build type: Release | ||||
| Tags | #lowhangingfruit | ||||
Considering the ensuing discussion in the linked topic, shouldn't this bug report be reworded? For example, "Add setting to disable automatic workbench switching". I very much like automatic workbench switching and would not want it to be prevented as the current bug description suggests. |
You are right, I should have named it like this. Maybe @DeepSOIC can change the title. |
As discussed, changed description from "Prevent automatic workbench switching". |
PR submitted |
FreeCAD: master 2756d46a 2019-09-08 16:09:29 0penBrain Committer: wmayer Details Diff |
PartDesign : make possible to prevent auto-switching to PartDesign WB when a Body is activated * Use a boolean parameter located at BaseApp/Preferences/Mod/PartDesign/SwitchToWB * resolves 0002703 |
Affected Issues 0002703 |
| mod - src/Mod/PartDesign/Gui/ViewProviderBody.cpp | Diff File | ||
| 2016-09-18 16:03 | nokian | New Issue | |
| 2016-09-18 18:48 | DeepSOIC | Product Version | => 0.17 |
| 2016-10-15 21:03 | normandc | Note Added: 0007378 | |
| 2016-10-15 21:45 | nokian | Note Added: 0007381 | |
| 2016-10-15 21:52 | normandc | Note Added: 0007382 | |
| 2016-10-15 21:52 | normandc | Summary | Prevent automatic workbench switching => Add setting to disable automatic workbench switching |
| 2017-02-02 00:41 | Kunda1 | Tag Attached: #lowhangingfruit | |
| 2019-09-08 16:32 | openBrain | Note Added: 0013556 | |
| 2019-09-09 13:19 | openBrain | Assigned To | => openBrain |
| 2019-09-09 13:19 | openBrain | Status | new => assigned |
| 2019-09-11 19:34 | wmayer | Changeset attached | => FreeCAD master 2756d46a |
| 2019-09-11 19:34 | wmayer | Note Added: 0013579 | |
| 2019-09-11 19:34 | wmayer | Assigned To | openBrain => wmayer |
| 2019-09-11 19:34 | wmayer | Status | assigned => closed |
| 2019-09-11 19:34 | wmayer | Resolution | open => fixed |
