| 0002705 | PartDesign | Bug | public | 2016-09-20 19:46 | 2018-09-23 08:36 |
| Reporter | ronp | Assigned To | |||
| Platform | Linux | OS | Ubuntu | OS Version | 14.04.5 LTS |
| Summary | 0002705: Changing pocket from "Through all" to "Dimension" causes further sketch based features to malfunction. | ||||
| Description | After changing an earlier pocket feature from "Through all" to "Dimension", further sketch based features malfunction. On the step to convert a sketch to a pocket or a pad, the model disappears. This is reversible using the undo command. | ||||
| Steps To Reproduce | 1 Open the attached ccc.fcstd 96025c591eb59b763c429f2010689b11 2 Toggle "case" to active body 3 Add sketch and pocket to one face to ensure working. 4 Change feature "wire-hole" from "Through all" to "Dimension" such as 1.5 in. 5 Attempt another sketch based feature such pad or pocket 6 On converting the sketch to pad or pocket, the model disappears 7 Undoing prior to step 4 restores normal function | ||||
| Additional Information | OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8442 (Git) Build type: Debug Branch: master Hash: 0ef07032fd29d77d58f3b68d7bc5d80fa6a2b78e Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 | ||||
Best to start a Forum thread before posting to the bug tracker. Please start one at http://forum.freecadweb.org/ and then bidirectionally link ticket <=> thread. Thanks. |
@ronp do you mind reattaching the fcstd file? We had a problem with our tracker and the file didn't survive the backup. |
@ronp ping |
This is a resubmission of a previously attached file. 96025c591eb59b763c429f2010689b11 ccc.fcstd |
@ronp thanks! @chrisb do you mind testing this? |
It seems this issue has been fixed in the meantime. With an old 0.17 development snapshot I could observe several problems but with the stable version the issue has disappeared. |
| 2016-09-20 19:46 | ronp | New Issue | |
| 2016-09-20 19:46 | ronp | File Added: ccc.fcstd | |
| 2017-02-04 03:48 | Kunda1 | Note Added: 0008203 | |
| 2017-02-04 03:48 | Kunda1 | Status | new => feedback |
| 2017-05-10 12:07 | Kunda1 | Note Added: 0008934 | |
| 2017-06-28 14:15 | Kunda1 | Note Added: 0009573 | |
| 2017-07-03 23:15 | ronp | File Added: ccc-2.fcstd | |
| 2017-07-03 23:15 | ronp | Note Added: 0009663 | |
| 2017-07-03 23:15 | ronp | Status | feedback => new |
| 2017-07-04 00:03 | Kunda1 | Note Added: 0009664 | |
| 2017-10-18 13:09 | wmayer | Project | FreeCAD => PartDesign |
| 2018-09-23 08:36 | wmayer | Status | new => closed |
| 2018-09-23 08:36 | wmayer | Resolution | open => fixed |
| 2018-09-23 08:36 | wmayer | Fixed in Version | => 0.17 |
| 2018-09-23 08:36 | wmayer | Note Added: 0011825 |
