| 0002717 | Part | Bug | public | 2016-09-30 21:34 | 2017-08-13 15:23 |
| Reporter | bitwise | Assigned To | Kunda1 | ||
| Platform | Windows 10 | OS | Windows 10 64bit Pro | ||
| Summary | 0002717: Access Violation creating sweep | ||||
| Description | I get an Access Violation at address 0x00000010 during 'READ' operation when attempting to create a sweep. | ||||
| Steps To Reproduce | Create a sweep by selecting the Profile sketch in the sweep dialog and click the lines in the Path sketch. Does not work with Create Solid check or not. | ||||
| Tags | sweep | ||||
I confirm the crash on OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6703 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 Oddly, if I run FreeCAD with gdb, I can't get a crash, and the Part Sweep partially succeeds: it sweeps one edge (left rounded corner of the profile). That being said, The vertical and horizontal lines at the centre of the profile are unnecessary, and would actually prevent Sweep from creating a solid (deleting them does not prevent the crash). I also do not understand why you created your profile with so many straight segments. Please explain what's your intention here. Did you want the sweep to generate separate coplanar faces? |
With a properly constrained Profile sketch, FreeCAD does not crash and the Part Sweep works as expected. See Bottom of Tiller_normandc2.fcstd. |
I found the problem: the Profile sketch contains a line that is overlapping two other lines. This can be seen in the Elements list. 13-Line overlaps 1-Line and 2-Line. There is also a useless point added at the origin. Granted FreeCAD should not crash, but this is an improper sketch to begin with. Therefore, it would have been more appropriate to talk about this in the forum first, as explained in the "Read this before reporting" link from the "ISSUES" menu. @ wmayer: do you think this bug report should be closed? |
I confirm the problem exists on my test case. It's reproducible in both last release versions - v0.16 and v0.15 It uses a simple circle sketch to sweep and a simple BSpline generated from macro as a path. Results are quite odd. When BSpline is short it sweeps successfully. When BSpline is longer - it fails with Input error: TCollection_IndexedDataMap::FindFromKey When BSpline is even more longer - it fails with ACCESS VIOLATION at address 0x00000000 during 'READ' operation I have attached my "sweep-error" test case. It contains all 3 cases. OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6706 (Git) Build type: Release Branch: releases/FreeCAD-0-16 Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4671 (Git) Branch: releases/FreeCAD-0-15 Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
tedbeer, using a BSpline as path sweep is a totally different issue. Please create a new bug report for it (maybe check if one already exists first). BTW it's been discussed lately on the forum. |
@tedbeer as per normandc please open a new bug (since I can't seem to find a relevant one) @wmayer as per normandc in 0002717:0007373 can this ticket be closed? |
@normandc please advise. Should we split the ticket to report the bspline issue and close this one? |
The bspline issue should be in a separate ticket, but tedbeer's macro to create the bspline path would be required. As for this bug report, as I wrote previously the crash is caused by an inappropriate profile, still it should throw an error rather than produce a crash. So the crash needs to be fixed. |
@kunda1 There is not crash anymore. The tool says "failed to validate broken face" until the profile sketch is corrected. OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11122 (Git) Build type: Debug Branch: occ_extra_info Hash: a0da4b16a8768779ce32480046d3c0109595d5e5 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 It got corrected somewhere. I would say we can close this ticket. |
Resolving per Abdullah. |
Closing |
| 2016-09-30 21:34 | bitwise | New Issue | |
| 2016-09-30 21:34 | bitwise | File Added: Bottom Of Tiller.FCStd | |
| 2016-10-15 20:14 | normandc | Note Added: 0007371 | |
| 2016-10-15 20:23 | normandc | File Added: Bottom Of Tiller_normandc2.FCStd | |
| 2016-10-15 20:24 | normandc | Note Added: 0007372 | |
| 2016-10-15 20:30 | normandc | Note Added: 0007373 | |
| 2016-10-15 21:29 | tedbeer | File Added: sweep-error.FCStd | |
| 2016-10-15 21:34 | tedbeer | Note Added: 0007379 | |
| 2016-10-15 21:35 | tedbeer | Note Edited: 0007379 | |
| 2016-10-15 21:37 | normandc | Note Added: 0007380 | |
| 2017-01-11 19:30 | Kunda1 | Note Added: 0007643 | |
| 2017-01-19 13:13 | Kunda1 | Tag Attached: #pending | |
| 2017-02-15 04:48 | Kunda1 | Note Added: 0008303 | |
| 2017-02-17 13:51 | Kunda1 | Tag Attached: sweep | |
| 2017-02-25 18:15 | normandc | Note Added: 0008432 | |
| 2017-02-25 21:39 | Kunda1 | Severity | major => crash |
| 2017-02-25 21:39 | Kunda1 | Status | new => confirmed |
| 2017-05-24 22:23 | abdullah | Note Added: 0009122 | |
| 2017-05-24 22:24 | Kunda1 | Tag Detached: #pending | |
| 2017-05-24 22:25 | Kunda1 | Status | confirmed => resolved |
| 2017-05-24 22:25 | Kunda1 | Resolution | open => fixed |
| 2017-05-24 22:25 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-05-24 22:25 | Kunda1 | Note Added: 0009123 | |
| 2017-06-17 23:43 | normandc | Project | PartDesign => Part |
| 2017-06-17 23:43 | normandc | Category | Bug => General |
| 2017-06-17 23:47 | normandc | Category | General => Bug |
| 2017-08-13 15:23 | Kunda1 | Assigned To | => Kunda1 |
| 2017-08-13 15:23 | Kunda1 | Status | resolved => closed |
| 2017-08-13 15:23 | Kunda1 | Note Added: 0009901 |
