0002718FreeCADGeneralpublic2017-02-02 20:56
Reporternesergen Assigned To
PlatformLinuxOSUbuntuOS Version16.04
Product Version0.16
Summary0002718: background color of the tooltips
DescriptionThe program FreeCAD background color of the tooltip (light blue), and the font color (pale gray) merge with each other, which makes difficult to read tips. In other programs, and in general in the interface of the system, the tips color black and white , this combination is perfect. I tried to change the tips color through settings ThemeConfiguration and through ".gtkrc-2.0", color changing system, and FreeCAD - no.
nesergen
2016-10-02 20:02
reporter
2016-10-04 18:23
administrator   ~0007342
Do you have activated a Qt style sheet in FreeCAD? Go to Edit > Preferences > General and check if a style sheet is selected. If no one is selected FreeCAD should follow system settings.
nesergen
2016-10-05 14:04
reporter   ~0007343
Yes, when I change "style sheet" the tooltips become readable, but not with system settings. And colors in "style sheet" is not pleasant. The same problem appear in skype.
2017-02-02 17:57
administrator   ~0008178
@nesergen please post your Help > About FreeCAD > Copy to clipboard
also post a little more specs about your system?
Especially Window Manager related stats.
2017-02-02 20:56
administrator   ~0008180
The important part is this:
So, it's clearly caused by system settings and why should we do something on this? The user should search through system settings and change the color.
2016-10-02 20:02 nesergen New Issue
2016-10-02 20:02 nesergen File Added: Screenshot_21-50-14.png
2016-10-04 18:23 wmayer Note Added: 0007342
2016-10-05 14:04 nesergen Note Added: 0007343
2016-10-05 14:05 nesergen Note Edited: 0007343
2017-02-02 17:57 Kunda1 Note Added: 0008178
2017-02-02 17:57 Kunda1 Status new => feedback
2017-02-02 20:56 wmayer Note Added: 0008180
2017-02-02 20:56 wmayer Status feedback => closed
2017-02-02 20:56 wmayer Resolution open => won't fix
