| 0002726 | FreeCAD | Bug | public | 2016-10-06 16:24 | 2017-07-11 20:12 |
| Reporter | hartl | Assigned To | yorik | ||
| Platform | Intel x86_64 | OS | Linux openSUSE | OS Version | Tumbleweed |
| Summary | 0002726: segfault when applying thicknes to extruded polygon or similar shape | ||||
| Description | using the thickness tool on extruded polygons, cubes, prisms, wedges crashes with: *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0 it seems that thickness only works with cylinders. objects with one surface (sphere and torus) will hang the program (endless loop, 100% load on one core, needs SIGKILL to stop). a cone, pointy or not, gives "Input error BRepAlgo_Image::Bind" | ||||
| Steps To Reproduce | 1. select Part workbench 2. create a cube (default values) -or- 2a. create a regular polygon (default values) 2b. extrude the polygon (default values) 3. select a face of the object 4. click on "thickness"-button -> crash | ||||
| Additional Information | OS: "openSUSE Tumbleweed" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8487 (Git) (Packman) Build type: Release Branch: master Hash: c457fc468cd57807586915ebfd288638f009281f Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.9.1.oce-0.18-dev Linux x6 4.7.5-1-default #1 SMP PREEMPT Mon Sep 26 08:11:45 UTC 2016 (02c4d35) x86_64 x86_64 x86_64 GNU/Linux | ||||
Can't reproduce here with OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8676 (Git) Build type: None Branch: master Hash: b8163a03dc80b64b38744ed1289e8a7bdab0d378 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 Forum users on OpenSUSE Tumbleweed have reported geometric problems that other users don't seem to suffer. Maybe the problem is with the OCC version used in SUSE (6.9.1.oce-0.18-dev). |
OCE from Packman repo seems to be broken or outdated. Compiling OCC 7.0.0 from opencascade.com and FreeCAD from GIT solved the issue with objects with more than 3 surfaces. Thickness on a sphere will still enter an inifinte loop, on a cone or truncated cone it will show strange behavoir if there is only one unselected surface. This looks like an independent bug, please advise if I should file a new report for that. OS: "openSUSE Tumbleweed" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8715 (Git) Build type: Unknown Branch: master Hash: fbaf3a1bbc818153d966ca49e910c6942f2581aa Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.0.0 Linux x6 4.7.6-1-default #1 SMP PREEMPT Fri Sep 30 12:22:14 UTC 2016 (fb37fcc) x86_64 x86_64 x86_64 GNU/Linux |
Packaging issue as mentioned 0002727 Someone should let the packman repo team know, unless they do already. Tagging #tobeclosed |
| 2016-10-06 16:24 | hartl | New Issue | |
| 2016-10-15 20:00 | normandc | Note Added: 0007370 | |
| 2016-10-18 16:47 | hartl | Note Added: 0007390 | |
| 2017-01-09 22:36 | Kunda1 | Tag Attached: #tobeclosed | |
| 2017-01-09 22:38 | Kunda1 | Note Added: 0007592 | |
| 2017-01-09 23:27 | yorik | Status | new => closed |
| 2017-01-09 23:27 | yorik | Assigned To | => yorik |
| 2017-01-09 23:27 | yorik | Resolution | open => no change required |
| 2017-07-11 20:12 | Kunda1 | Tag Detached: #tobeclosed |
