| 0002729 | GCS | Bug | public | 2016-10-07 21:00 | 2018-06-03 07:57 |
| Reporter | Chukharev | Assigned To | chrisb | ||
| Platform | Unix | OS | FreeBSD | OS Version | 10.3-STABLE |
| Summary | 0002729: False 'redundant constrains' message | ||||
| Description | While learning macro facilities of FreeCAD I found a bug. It's currently better to use 'incorrect' sizes for a sketch preliminary shape and use constrains to amend the sizes. With the correct sizes, solver sometimes fails to apply the constrains, falsely complaining about redundant constrains. | ||||
| Steps To Reproduce | 0. Save the attached file Attempt_002.FCMacro to the folder for your macros 1. Open FreeCAD 2. Press the "create new document" button 3. Switch to the Part Design workbench 4. Press the "Create Body" link 5. Press the "Create sketch" link 6. Select "YZ_Plane (Base plane)" and press OK button 7. Start editing the saved macro: a) Menu Macro -> Macros... b) Select Attempt_002.FCMacro and press Edit 8. Run opened macro by pressing Ctrl+F6 (or corresponding button) 9. Verify that in the "Unnamed: 1" tab a fully constrained sketch is created. 10. Select all edges and delete them from the sketch 11. Switch to the tab of macro editing 12. Uncomment the line number 10 and comment out line 11 (they do almost the same) 13. Run opened macro by pressing Ctrl+F6 (or corresponding button) 14. See in Solver messages: Sketch contains redundant constrains... | ||||
| Additional Information | $ uname -a FreeBSD vovaasus 10.3-STABLE FreeBSD 10.3-STABLE 0000021 r306257: Sat Sep 24 02:05:50 EEST 2016 root@vovaasus:/usr/obj/usr/src/sys/GENERIC amd64 From Help->About FreeCAD: OS: UNIX Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.Unknown Build type: Release Python version: 2.7.12 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.9.1 | ||||
| Tags | Solver | ||||
Works perfectly well here. Both lines lead to fully constrained sketches. OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8614 (Git) Build type: None Branch: master Hash: a50bd5dc880f76c3ba8b7af5bd5d19799db4cbf1 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
A newer version of FreeCAD arrived on FreeBSD too, but it does not change the situation for me. One line produces a fully constrained sketch, the other - over constrained. The new version is called in FreeBSD terms FreeCAD-0.17.g20160927, and it gives the following info. OS: UNIX Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.6700 Build type: Release Python version: 2.7.12 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.9.1 I do not know how to compare the versions... |
The most reliable way to compare FreeCAD versions should be the hash, which refers to the git commit. But your FreeBSD builds do not provide it (see jnxd's FreeCAD info). If the latest build is from 2016-09-27, the version number (0.17) and revision number (6700) do not make sense, because the 0.17 development branch was started *after* the 6700th revision (Git revisions are IDed as hashes, I believe that at compile time there's a script that counts the number of commits to get the revision number). Your FreeCAD info also does not provide the branch it was built from. There is a "releases/FreeCAD-0-16" branch from which your version may be built from, and a master branch which hosts 0.17 development. As it is it is AFAIK impossible to figure out. I recommend you contact the people responsible for the FreeCAD builds on FreeBSD so they are aware of the missing info provided in their builds. Tell them that the compilation process generates a /src/Version.h file from the /src/Version.h.cmake file. For it to work compilation must be done in a Git repo. They may want to join the forum to ask further details to the FreeCAD developers. |
I have asked the maintainer of the FreeBSD port of FreeCAD to join this discussion. IMNSHO the demand "compilation must be done in a Git repo" is overly restrictive. It makes any other source distribution than a git fork practically forbidden. Usually, version control systems allow to automate updating a version number, directly or using a commit hook. It's hard for me to believe Git does not allow it. The FreeBSD port contains a line "GH_TAGNAME=958686d". Also, the distfile is named FreeCAD-FreeCAD-0.17.g20160927-958686d_GH0.tar.gz. My guess is that the tag 958686d is related to the Git revision hash you are talking about, even though it's much shorter than shown by the ubuntu build. Does this info help to compare the versions? |
Yes it helps (I think). In theory it should be this commit: https://github.com/FreeCAD/FreeCAD/commit/958686d The commit dates from 19 days ago which corresponds to the date in the distfile name. So the "6700" revision number is definitely wrong. Two methods to find out the revision number are shown in this forum topic: http://forum.freecadweb.org/viewtopic.php?f=10&t=5308 The revision number for 958686d is 8539. It is from the master branch. But this is a bug tracker, not a discussion forum. Further discussion should be done in the FreeCAD forum. |
The problem with git is that hashes are not consecutive and are not an indicative of exactly which version you are using, so for the package I include the date the snapshot was taken from. the port Makefile defines: GH_TAGNAME= 958686d So we are talking of a snapshot from here: https://github.com/FreeCAD/FreeCAD/commit/958686d7b9e94caf0c0558cffc7bbf4f03ce8f21 Is there an option to produce more debug information (perhaps avoiding the RELEASE option?). |
I've made a patch for the FreeBSD port of FreeCAD to build the same version from Git as was shown for Ubuntu by jnxd. It bails to -DISTVERSION= 0.17.g20160927 +DISTVERSION= 0.17.g20161008 and -GH_TAGNAME= 958686d +GH_TAGNAME= a50bd5d (for those who use FreeBSD). Unfortunately, the bug is reproduced with the new version too. Any further suggestions? I mean, how to debug it now? |
The bug is reproduced also with the FreeCAD built from the newest possible sources with last commit made today 8h ago, the only commit today till this moment. Could anybody tell if the difference of Coin version can be the reason for bug not being observed on Ubuntu? FreeBSD has the latest released Coin version 3.1.3. Ubuntu uses a not yet released version 4.0.0a., see above Note 0007354. |
Bug is reproducible on Win10. (I needed to comment out "import Show.TempoVis".) OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6706 (Git) Build type: Release Branch: releases/FreeCAD-0-16 Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
I've cloned Git and compiled within the repo. Bug is still reproducible. Now, I'd like somebody to reconfirm that the bug can not be reproduced on Ubuntu. Note that Coin version 4.0.0a does not fix the bug on Win10... OS: UNIX Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8716 (Git) Build type: Release Branch: master Hash: ec0f8082b2a284f86ab44e016bc5991c38667a6a Python version: 2.7.12 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.9.1 |
Reproducible also with: OS: UNIX Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9023 (Git) Build type: Release Branch: master Hash: de8bfaafc3d6a4360e6a5871d56ddaf28aca699e Python version: 2.7.12 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.9.1 |
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19825 |
@Chukharev According to the forum and testers this seems to be a workflow issue rather than software. Please see https://forum.freecadweb.org/viewtopic.php?f=10&t=19825#p153066 |
My opinion is that a bug is a bug. And it should be fixed. Particularly when at least two strategies of fixing it are suggested. 1. Try to slightly randomly displace points and rerun the solver. This is shown to help in my report. Admittedly, this is not a very reliable way to a solution... 2. Completely forbid the combination and/or do an automatic substitution of a close equivalent. This has been suggested in the forum. The third strategy might be to detect the situation and just tell the user a better way to achieve the result. |
@Chukharev please respond in the forum thread to continue the conversation. Thanks |
In the meantime the tangency+coincident automatic conversion to endpoint tangency was implemented and merged into master. This should then be fixed in the sense that that combination can not be generated (by the user, can still be done from Python, but that is a power user looking for trouble). I think this should be marked as "fixed" in the sense that it has been effectively "worked around". |
Fixed the MMacro by replacing Part.Line with Part.LineSegment. With this modification both versions are okk in Abdullahs improved sketcher branch. Can be closed as soon as this is in Master AttemptFixed.FCMacro (2,100 bytes)
# -*- coding: utf-8 -*-
# Macro Begin: /home/chu/.FreeCAD/Macro/Atempt_001.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++
import FreeCAD
import PartDesign
import Sketcher
import math
#App.ActiveDocument.Sketch.addGeometry(Part.ArcOfCircle(Part.Circle(App.Vector(0, 8, 0), App.Vector(0, 0, 1), 1.5), 0, math.pi), False) # e 0, p 1..3
App.ActiveDocument.Sketch.addGeometry(Part.ArcOfCircle(Part.Circle(App.Vector(0, 8, 0), App.Vector(0, 0, 1), 1.5), math.pi/4, math.pi*3/4), False) # e 0, p 1..3
App.ActiveDocument.Sketch.addGeometry(Part.LineSegment(App.Vector(-1, 9, 0), App.Vector(-1, 0, 0)), False) # e 1, p 1..2
App.ActiveDocument.Sketch.addGeometry(Part.LineSegment(App.Vector(-1, 0, 0),App.Vector(1, 0, 0)),False) # e 2, p 1..2
App.ActiveDocument.Sketch.addGeometry(Part.LineSegment(App.Vector(1, 0, 0),App.Vector(1, 9, 0)),False) # e 3, p 1..2
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident', 0, 2, 1, 1)) # c 1
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident', 1, 2, 2, 1)) # c 2
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident', 2, 2, 3, 1)) # c 3
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident', 3, 2, 0, 1)) # c 4
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Vertical', 1)) # c 5
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Horizontal', 2)) # c
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Vertical', 3)) # c 7
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Tangent', 0, 1)) # c 8
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Tangent', 3, 0)) # c 9
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('DistanceY', -1, 1, 0, 3, 8.0)) # c 10
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Symmetric',1,2,2,2,-1,1)) # c 11
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('DistanceX', 2, 1, 2, 2, 2.0)) # c 12
App.ActiveDocument.recompute()
# Macro End: /home/chu/.FreeCAD/Macro/Atempt_001.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++ |
https://github.com/FreeCAD/FreeCAD/pull/1429 |
| 2016-10-07 21:00 | Chukharev | New Issue | |
| 2016-10-07 21:00 | Chukharev | File Added: Atempt_002.FCMacro | |
| 2016-10-10 15:22 | jnxd | Note Added: 0007354 | |
| 2016-10-10 20:03 | Chukharev | Note Added: 0007356 | |
| 2016-10-15 19:32 | normandc | Note Added: 0007367 | |
| 2016-10-16 09:04 | Chukharev | Note Added: 0007384 | |
| 2016-10-16 15:11 | normandc | Note Added: 0007386 | |
| 2016-10-16 16:04 | pgiffuni | Note Added: 0007387 | |
| 2016-10-17 16:02 | Chukharev | Note Added: 0007389 | |
| 2016-10-18 20:18 | Chukharev | Note Added: 0007393 | |
| 2016-10-19 06:50 | Chukharev | Note Edited: 0007393 | |
| 2016-10-19 06:53 | Chukharev | Note Added: 0007395 | |
| 2016-10-19 06:55 | Chukharev | Note Edited: 0007395 | |
| 2016-10-19 10:37 | Chukharev | Note Added: 0007396 | |
| 2016-11-26 22:28 | Chukharev | Note Added: 0007491 | |
| 2017-01-13 00:05 | Kunda1 | Note Added: 0007696 | |
| 2017-02-02 14:33 | Kunda1 | Note Added: 0008173 | |
| 2017-02-02 14:33 | Kunda1 | Status | new => feedback |
| 2017-02-03 22:46 | Chukharev | Note Added: 0008199 | |
| 2017-02-03 22:46 | Chukharev | Status | feedback => new |
| 2017-02-04 01:09 | Kunda1 | Note Added: 0008201 | |
| 2017-02-04 01:09 | Kunda1 | Status | new => feedback |
| 2017-05-10 12:04 | Kunda1 | Tag Attached: Solver | |
| 2018-04-27 10:00 | abdullah | Note Added: 0011205 | |
| 2018-04-27 21:04 | chrisb | File Added: AttemptFixed.FCMacro | |
| 2018-04-27 21:04 | chrisb | Note Added: 0011211 | |
| 2018-06-03 07:57 | chrisb | Assigned To | => chrisb |
| 2018-06-03 07:57 | chrisb | Status | feedback => closed |
| 2018-06-03 07:57 | chrisb | Resolution | open => fixed |
| 2018-06-03 07:57 | chrisb | Note Added: 0011344 |
