| 		 | Hi. I just created a script for the creation of a digest of SHA-256 checksums of the files in a directory. You can control the 'base directory', the 'output directory' and the 'block size' (read at most 'block size' bytes from each file).
 It is python 2.7 compatible code, as sys.version in FreeCAD 0.17 prints:
 '2.7.14 (default, Jan 16 2018, 16:11:42) [MSC v.1800 64 bit (AMD64)'
 Hopefully it will help with the automated creation of digests of hashes of future releases. I also published it as a gist, but I'm unsure that -- as a newly registered user -- that I can paste URLs here and not get automatically flagged as a spammer.
 So, here's the code of sha256digest.py:
# -*- coding: utf-8 -*-
Script to create SHA-256 digest of all files in the current directory
Based on an answer by Richard Neumann on Code Review
https://codereview.stackexchange.com/a/147191
Based on recommendation that file digests are created nowadays
https://en.wikipedia.org/wiki/File_verification#File_formats
Created on Fri Apr 20 12:07:41 2018
@author: rolandog
from os import getcwd, listdir
from os.path import join, isfile
from time import strftime
from hashlib import sha256
def list_files(basedir=None):
    """List only files within the respective directory"""
    if basedir is None:
        basedir = getcwd()
    for item in listdir(basedir):
        path = join(basedir, item)
        # skip listing a hash of our hash digest
        if "sha256-digest" in item:
            continue
        if isfile(path):
            # changed so that we get the path and the filename
            yield (path, item)
def sha256sum(file_name, block_size=None):
    """Returns the sha256 checksum of the respective file"""
    if block_size is None:
        block_size = 4096
    checksum = sha256()
    with open(file_name, "rb") as file_handle:
        block = file_handle.read(block_size)
        while block:
            checksum.update(block)
    return checksum.hexdigest()
def sha256sums(basedir=None, block_size=None):
    """Yields (<sha256sum>, <file_name>) tuples
    for files within the basedir.
    for file_path, file_name in list_files(basedir=basedir):
        yield (sha256sum(file_path, block_size=block_size), file_name)
def create_sha256_digest(basedir=None, block_size=None, outputdir=None):
    """Creates de sha256-digest file with a timestamp"""
    hash_file_name = strftime("sha256-digest_%Y%m%d-%H%M%S")
    if outputdir is None:
        outputdir = getcwd()
    hash_file_path = join(outputdir, hash_file_name)
    with open(hash_file_path, "w") as file_handle:
        for file_hash in sha256sums(basedir, block_size):
            file_handle.write(" *".join(file_hash) + "\n")
if __name__ == "__main__":
    import argparse
    PARSER = argparse.ArgumentParser()
    PARSER.add_argument("-d",
                        "--directory",
                        default=None,
                        type=str,
                        required=False,
                        help="Path, str, to the directory of the files")
    PARSER.add_argument("-b",
                        "--blocksize",
                        default=None,
                        type=int,
                        required=False,
                        help="Block size, int, in bytes to read from files")
    PARSER.add_argument("-o",
                        "--outputdir",
                        default=None,
                        type=str,
                        required=False,
                        help="Output directory, str, for sha256 digest")
    ARGUMENTS = PARSER.parse_args()
    create_sha256_digest(basedir=ARGUMENTS.directory,
                         block_size=ARGUMENTS.blocksize,
                         outputdir=ARGUMENTS.outputdir)
		| 		 | I updated my script so that it has a permissive license and that it can also output individual sha256 files (if needed), though it defaults to a digest of checksums and filenames:
Purpose
Creates a SHA-256 digest of files in a directory
Attributions
Based on statement that file digests are considered best-practice as of 2012
Creation and Modification Times
Last Modified on Mon Apr 23 09:50:21 2018
License
License: Creative Commons CC0
License URL: https://creativecommons.org/publicdomain/zero/1.0/legalcode
Changelog
* 0.0.2
    - Added option to request individual files instead of digest
    - Don't output hash of currently running script
    - Added changelog
    - Added last modified date
    - Added example usage by developer and end-user
    - Added Creative Commons CC0 License
* 0.0.1
    - Initial release.
@author: rolandog
@version: 0.0.2
from os.path import join, isfile, basename
from textwrap import dedent
    if basedir is None:
        basedir = getcwd()
    # gets the name of the running script
    script_name = basename(__file__)
        # don't make a hash of a hash file or current file
        if "sha256-digest" in item or ".sha256" in item or script_name in item:
            continue
        if isfile(path):
            yield (path, item)
        block_size = 4096
    checksum = sha256()
        while block:
                         block_size=None,
                         outputdir=None,
                         individual=False):
    if individual is False:
    else:
        for checksum, file_name in sha256sums(basedir, block_size):
            hash_file_name = file_name + ".sha256"
                file_handle.write(" *".join((checksum, file_name)) + "\n")
    from argparse import ArgumentParser, RawDescriptionHelpFormatter
    DESCRIPTION = "Creates a SHA-256 digest of files in a directory"
    EPILOG = """\
        ls
            hello-world.txt  sha256digest.py
        cat hello-world.txt
            Hello, World!
        python sha256digest.py -i
        ls
            hello-world.txt  hello-world.txt.sha256  sha256digest.py
        cat hello-world.txt.sha256
            c98c24b677eff44860afea6f493bbaec5bb1c4cbb209c6fc2bbb47f66ff2ad31 *hello-world.txt
        example usage by end-user
        ls
        sha256sum -c hello-world.txt.sha256
            hello-world.txt: OK
    PARSER = ArgumentParser(prog="sha256digest.py",
                            description=DESCRIPTION,
                            formatter_class=RawDescriptionHelpFormatter,
                            epilog=dedent(EPILOG))
    PARSER.add_argument("-i",
                        "--individual",
                        default=False,
                        action="store_true",
                        required=False,
                        help="outputs one hash file per file in folder")
                        "--directory",
                        default=None,
                        type=str,
                        required=False,
                        help="path to the folder containing the files")
                        "--blocksize",
                        default=None,
                        type=int,
                        required=False,
                        help="read files in chunks less than BLOCKSIZE bytes")
                        "--outputdir",
                        default=None,
                        type=str,
                        required=False,
                        help="output directory for sha256 digest or files")
                         outputdir=ARGUMENTS.outputdir,
                         individual=ARGUMENTS.individual)
