| 0002751 | Path | Feature | public | 2016-10-28 03:57 | 2019-07-29 15:06 |
| Reporter | sliptonic | Assigned To | mlampert | ||
| Summary | 0002751: Holding tab dressup | ||||
| Description | Holding tabs are done now only for profile operations using libarea. This is legacy code built into the libarea implementation. While it works, it is limited, complicated, and difficult to maintain. It's also not possible to add holding tags to paths generated with OCC offsetting or with paths imported from external sources. A better solution will be to write a generic dressup operation that could be applied to any kind of profile operation and add holding tags at the identified locations with the specified properties. | ||||
FreeCAD: master f2c884a8 2017-01-12 21:57:29 wwmayer Committer: GitHub Details Diff |
Merge pull request 0000432 from mlampert/HoldingTags Path: Holding tags dressup, fixes tracker 0002751 |
Affected Issues 0002751 |
| mod - src/Mod/Path/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Path/Gui/Resources/Path.qrc | Diff File | ||
| mod - src/Mod/Path/Gui/Resources/panels/HoldingTagsEdit.ui | Diff File | ||
| add - src/Mod/Path/Gui/Resources/panels/PointEdit.ui | Diff File | ||
| add - src/Mod/Path/Gui/Resources/preferences/PathDressupHoldingTags.ui | Diff File | ||
| mod - src/Mod/Path/InitGui.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathDressupHoldingTags.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathGeom.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathPreferences.py | Diff File | ||
| add - src/Mod/Path/PathScripts/PathPreferencesPathDressup.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathPreferencesPathJob.py | Diff File | ||
| 2016-10-28 03:57 | sliptonic | New Issue | |
| 2016-10-28 18:24 | mlampert | Assigned To | => mlampert |
| 2016-10-28 18:24 | mlampert | Status | new => assigned |
| 2017-01-12 20:59 | wmayer | Note Added: 0007685 | |
| 2017-01-12 20:59 | wmayer | Status | assigned => closed |
| 2017-01-12 20:59 | wmayer | Resolution | open => fixed |
| 2017-01-12 20:59 | wmayer | Fixed in Version | => 0.17 |
| 2019-07-29 15:06 | Kunda1 | Changeset attached | => FreeCAD master f2c884a8 |
