| 0002758 | PartDesign | Bug | public | 2016-11-05 12:36 | 2018-07-12 03:47 |
| Reporter | Pauvres_honteux | Assigned To | DeepSOIC | ||
| Platform | x86_64 | OS | openSUSE Leap | OS Version | 42.1 |
| Summary | 0002758: Datum point moves to (0,0,0) when reopening the file. | ||||
| Description | OS: "openSUSE Leap 42.1 (x86_64)" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8819 (Git) (Packman) Build type: Release Branch: master Hash: 195ea429e696377980b4edbf4a4affdb1f46abaa Python version: 2.7.12 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.9.1.oce-0.18-dev When reopening a file containing a DatumPoint, that DatumPoint has moved to (0,0,0) from its original position. | ||||
| Steps To Reproduce | Create a new document. Choose PartDesign workbench. Create a new Part and make it active. Create a new Body and make it active. In the Body, create a new DatumPoint and choose Attachment mode: "Object's origin", click OK. In DatumPoint's Data-tab, set X=5, Y=10, Z=15. Save the file with a name. Close the program. Open the program and the named file. In Data-tab, read the values for the DatumPoint. It is now (0,0,0). | ||||
| Additional Information | Attaching a DatumPlane and/or a sketch to that DatumPoint will result in a linkage loss at save/open. Though it seams as if the DatumPlane and/or sketch has created a copy of the DatumPoint position, i.e. anything connected to the DatumPlane and/or sketch is still intact after reopening the file. Moving the DatumPoint will not result in any position changes of the DatumPlane and/or sketch. | ||||
| Tags | lines, Part Design, Placement, planes, points | ||||
Related discussion: http://forum.freecadweb.org/viewtopic.php?f=8&t=17630&start=10 |
More information in this issue in attached PDF. |
https://github.com/FreeCAD/FreeCAD/commit/d2ee3d2ac09bf1c1f32f42e8a971d27c601d9e4a |
Reopening, because my fix was incomplete. Datum point shape is restored after Datum::Point::Restore is finished, so recreation of shape does not do what it was supposed to. |
fixed by https://github.com/FreeCAD/FreeCAD/commit/8a7525f620db88dbd8082b44641f5d905e6c43bb |
@DeepSOIC can this ticket be closed ? |
@DeepSOIC ping |
Closing |
| 2016-11-05 12:36 | Pauvres_honteux | New Issue | |
| 2016-11-05 12:39 | Pauvres_honteux | Tag Attached: Part Design | |
| 2016-11-05 12:39 | Pauvres_honteux | Tag Attached: Placement | |
| 2016-11-05 12:39 | Pauvres_honteux | Tag Attached: planes | |
| 2016-11-05 12:39 | Pauvres_honteux | Tag Attached: points | |
| 2016-11-05 12:46 | Pauvres_honteux | Note Added: 0007442 | |
| 2016-11-29 14:18 | ickby | Assigned To | => ickby |
| 2016-11-29 14:18 | ickby | Status | new => assigned |
| 2018-01-21 12:13 | Pauvres_honteux | Tag Attached: lines | |
| 2018-01-21 12:15 | Pauvres_honteux | File Added: Point_Line_Plane_Sketch_Pad.pdf | |
| 2018-01-21 12:15 | Pauvres_honteux | Note Added: 0010804 | |
| 2018-04-04 15:55 | wmayer | Assigned To | ickby => DeepSOIC |
| 2018-04-04 15:55 | wmayer | Status | assigned => closed |
| 2018-04-04 15:55 | wmayer | Resolution | open => fixed |
| 2018-04-04 15:55 | wmayer | Fixed in Version | => 0.17 |
| 2018-04-04 15:55 | wmayer | Note Added: 0011123 | |
| 2018-04-11 15:07 | DeepSOIC | Status | closed => feedback |
| 2018-04-11 15:07 | DeepSOIC | Resolution | fixed => reopened |
| 2018-04-11 15:08 | DeepSOIC | Note Added: 0011140 | |
| 2018-04-11 15:09 | DeepSOIC | Note Edited: 0011140 | |
| 2018-05-13 16:34 | DeepSOIC | Note Added: 0011248 | |
| 2018-05-13 16:36 | DeepSOIC | Status | feedback => resolved |
| 2018-05-13 16:36 | DeepSOIC | Resolution | reopened => fixed |
| 2018-05-21 10:07 | Kunda1 | Note Added: 0011266 | |
| 2018-06-10 22:11 | Kunda1 | Note Added: 0011399 | |
| 2018-07-12 03:47 | Kunda1 | Status | resolved => closed |
| 2018-07-12 03:47 | Kunda1 | Note Added: 0011513 |
