| 0002774 | Sketcher | Feature | public | 2016-11-16 11:16 | 2021-02-06 06:48 |
| Reporter | Joachimthome | Assigned To | |||
| Platform | Lenovo x220 | OS | Linux | OS Version | Ubuntu 14.04.5 |
| Summary | 0002774: Can not select points in sketcher properly when changing viewangle | ||||
| Description | When i try to edit a sketch and change to "bottom" view (default shortcut "5") i can not select the dots in the sketch properly anymore. The same thing happens in the other two planes also. switching back to "top" view makes it possible again. Even selecting via drag selection leads to buggy behaviour where i can not select the (0,0,0)point properly. Its not a major issue but inconvenient. | ||||
| Steps To Reproduce | start freecad 0.16 open a new freecad project got to part design workbench click create new sketch choose xy plane use the line tool to make a line press 5 to change to bottom view try to select endpoints of line > the line gets selected instead | ||||
| Additional Information | OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6703 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
Can't reproduce on 0.16 (d/led via AUR) OS: "Manjaro Linux" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.Unknown Build type: Release Python version: 2.7.12 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.9.1 |
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=8&t=19798 |
@sgrogan writes in http://forum.freecadweb.org/viewtopic.php?f=8&t=19798&p=152873#p152873 > I can reproduce it, but I think its the intended behavior. In the Top View the points are "over" the line so they can be selected. In the Bottom view the points are "under" the line so the line is selected. I don't have any problems with box selection it works as expected. > Switch to the front view and zoom way in on an endpoint to see. |
confirmed but is it , a bug, or made on purpose regarding the orientation of the sketch...and with 0.17 and the "map reversed" option, I don't think it's still valid |
Changing ticket to Feature Request per @DeepSOIC in https://forum.freecadweb.org/viewtopic.php?f=8&t=19798&start=10#p154435 |
With the inclusion of the "reverse mapping" and the clip planes (section view), it is more and more difficult to find actual scenarios when one shall rotate the sketcher view in order to operate. This was certainly difficult before. In the next development cycle we should look into whether there is a need or not. |
This ticket has been migrated to GitHub as issue 5673. |
| 2016-11-16 11:16 | Joachimthome | New Issue | |
| 2017-01-11 19:01 | Kunda1 | Summary | Can not select points in scetcher properly when changing viewangle => Can not select points in sketcher properly when changing viewangle |
| 2017-01-11 19:14 | Kunda1 | Note Added: 0007641 | |
| 2017-01-11 19:17 | Kunda1 | Note Added: 0007642 | |
| 2017-01-11 19:58 | Kunda1 | Note Added: 0007647 | |
| 2017-01-14 08:43 | nemesis | Note Added: 0007755 | |
| 2017-05-26 20:25 | Kunda1 | Category | Bug => Feature |
| 2017-05-26 20:25 | Kunda1 | Note Added: 0009156 | |
| 2018-10-06 15:10 | abdullah | Note Added: 0011947 | |
| 2018-10-06 15:11 | abdullah | Target Version | => 0.19 |
