| 0002776 | FreeCAD | Bug | public | 2016-11-17 23:55 | 2017-04-28 19:28 |
| Reporter | makewrite | Assigned To | |||
| Platform | X86-64 | OS | Linux Mint Xfce | OS Version | 18 |
| Summary | 0002776: Varying responses to filletting. | ||||
| Description | See the uploaded file. Make the object "to be filleted" visible, and the part design workbench available. I wish to fillet the between the horizontal wings and the main body. Along edges 42 & 123 on one side and 90 & 33 on the other side. If and only if I select edge 42 the fillet option will work and up to radii of 3mm. Any other combination of the edges 123, 90, & 33 with or without edge 42 will fail the object simply won't be drawn. | ||||
| Steps To Reproduce | Follow the description above. | ||||
| Additional Information | Would have expected it to have worked on either side. Also would have expected to have selected both edges to get the result. I was not really expecting the fillet to work at all but seeing as it made such a good job when edge 42 was selected it clearly is intended to work as well as it can. | ||||
The report view contains no extra information. |
Granted this should not happen, but your model is completely shot. Have a look at Tools --> Dependency graph. I have no idea how it happened, but the history of your model is broken. You have 3 separate branches, with the "To be filleted" branch having no link to features prior to Pad008. |
There's a residual edge on the underside of the model left by Fusion001. You should not have made the bottom edge of Pad009 at the same Z height as the bottom of the base. Even though Check Geometry reports Fusion001 as a valid solid, this kind of situation should be avoided. I feel that you should have reported your problems on the forum first so experienced users could diagnose your model. |
@makewrite this ticket has a high probability that it's workflow related and not FreeCAD. Are you planning to follow-up based on 0002776:0007481 by posting your issue to the forum? |
Resolving as 'no change required' per normandc's feedback, unless OP follows-up then we can re-open ticket. |
| 2016-11-17 23:55 | makewrite | New Issue | |
| 2016-11-17 23:55 | makewrite | File Added: a.fcstd | |
| 2016-11-18 00:05 | makewrite | Note Added: 0007464 | |
| 2016-11-20 20:44 | normandc | Note Added: 0007480 | |
| 2016-11-20 20:52 | normandc | Note Added: 0007481 | |
| 2017-03-20 21:39 | Kunda1 | Status | new => feedback |
| 2017-03-20 21:39 | Kunda1 | Note Added: 0008667 | |
| 2017-03-20 21:41 | Kunda1 | Status | feedback => resolved |
| 2017-03-20 21:41 | Kunda1 | Resolution | open => no change required |
| 2017-03-20 21:41 | Kunda1 | Note Added: 0008668 | |
| 2017-04-28 19:28 | Kunda1 | Status | resolved => closed |
