| 0002791 | FreeCAD | Feature | public | 2016-11-22 12:25 | 2017-07-11 20:09 |
| Reporter | agryson | Assigned To | eivindkvedalen | ||
| Platform | All | OS | All | ||
| Summary | 0002791: Allow use of Formulae in Placement menu | ||||
| Description | Formulae can be used in many operations and in many workbenches to calculate a value. This is particularly useful when global variables have been set up (through aliases in a spreadsheet). When manually changing the placement of a part, sketch or component, the fields do not allow the use of formulae. Being able to set a placement through a formula would simplify many placement tasks. | ||||
| Steps To Reproduce | (Following is just one example) Create a fully constrained sketch Go to its placement menu Fields only allow values to be entered, not formulae. | ||||
| Additional Information | I tried to find a similar request in the tracker but did not. | ||||
| Tags | spreadsheet | ||||
If you access the Placement property from the Data tab for the sketch (or any other object), you can enter formulas there. |
Ah, my apologies, I was looking at the menu after the elipsis button in the placement field. Excuse me for the waste of a ticket (also, I hadn't seen the request to discuss these kinds of things on the forum before creating a ticket - I'll do that next time) |
Reminder sent to: eivindkvedalen @eivindkvedalen do you want to keep this ticket open? |
@Kunda1 As the reporter, I can't close this, but it was back in my wasteful youth when I didn't read the guideliens before opening my mouth... :oops: You can safely close this. |
Functionality already provided in Properties editor. |
| 2016-11-22 12:25 | agryson | New Issue | |
| 2016-11-22 12:25 | agryson | File Added: Formulae.PNG | |
| 2016-11-23 23:40 | eivindkvedalen | Note Added: 0007486 | |
| 2016-11-24 08:27 | agryson | Note Added: 0007487 | |
| 2017-01-19 14:26 | Kunda1 | Note Added: 0007879 | |
| 2017-01-19 14:27 | Kunda1 | Tag Attached: #pending | |
| 2017-01-19 14:27 | Kunda1 | Tag Attached: spreadsheet | |
| 2017-01-19 15:03 | agryson | Note Added: 0007881 | |
| 2017-01-28 11:55 | eivindkvedalen | Note Added: 0008044 | |
| 2017-01-28 11:55 | eivindkvedalen | Status | new => closed |
| 2017-01-28 11:55 | eivindkvedalen | Assigned To | => eivindkvedalen |
| 2017-01-28 11:55 | eivindkvedalen | Resolution | open => no change required |
| 2017-07-11 20:09 | Kunda1 | Tag Detached: #pending |
