| 0002792 | Draft | Bug | public | 2016-11-23 04:53 | 2018-03-08 15:48 |
| Reporter | TomV | Assigned To | yorik | ||
| Platform | Linux | OS | Ubuntu | OS Version | 16.04.1 LTS |
| Target Version | 0.18 | Fixed in Version | 0.17 | ||
| Summary | 0002792: Negative distances measured in feet/inch calculated incorrectly | ||||
| Description | When specifying a negative distance in <ft>'<inch>", such a -7'3", FreeCAD actually calculated the following distance: -7' + 3" = -6'9" This is obviously wrong... | ||||
| Steps To Reproduce | - Set units to ft/inch - Create an object - select move object - select relative / copy - specify second point as -7'3" In the python console, you'll see the following: >>> Draft.move([FreeCAD.ActiveDocument.Rectangle001],FreeCAD.Vector(0.0,-2057.4,0.0),copy=True) -2057.4 = -6'9" instead of -7'3" | ||||
| Additional Information | OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8939 (Git) Build type: None Branch: master Hash: cb16eda2165d1af34ebbd73628f82aa00037f667 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | python, unicode, units | ||||
Started forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19794 |
Part of a larger issue: https://forum.freecadweb.org/viewtopic.php?f=10&t=7182 Problem with negative values in InputField |
The problem is that the unit parser currently has problems understanding these complex unit notations... The 7'+3" is a (bad) workaround I found provisorily. The unit parser actually needs to be extended to understand things like 7'3" or 7'3 1/4"... |
Keep in the 0.17 roadmap or bump to 0.18 ? |
Fixed in https://github.com/FreeCAD/FreeCAD/commit/46acd2f6a2ad32cb3ed56b551925dd483e8a55bc This is somewhat of a "hack" (notation now is -7'-3") but at least it works and is mathematically consistent... |
| 2016-11-23 04:53 | TomV | New Issue | |
| 2017-01-11 18:12 | Kunda1 | Note Added: 0007637 | |
| 2017-01-23 22:20 | Kunda1 | Tag Attached: units | |
| 2017-02-15 07:08 | kkremitzki | Status | new => confirmed |
| 2017-02-15 07:08 | kkremitzki | Target Version | => 0.17 |
| 2017-07-16 11:38 | Kunda1 | Note Added: 0009763 | |
| 2017-07-19 01:03 | yorik | Note Added: 0009779 | |
| 2017-10-10 02:17 | Kunda1 | Tag Attached: unicode | |
| 2017-11-05 13:53 | Kunda1 | Tag Attached: python | |
| 2017-11-29 00:58 | Kunda1 | Note Added: 0010498 | |
| 2018-03-07 19:06 | wmayer | Target Version | 0.17 => 0.18 |
| 2018-03-08 15:47 | yorik | Note Added: 0011024 | |
| 2018-03-08 15:48 | yorik | Assigned To | => yorik |
| 2018-03-08 15:48 | yorik | Status | confirmed => closed |
| 2018-03-08 15:48 | yorik | Resolution | open => fixed |
| 2018-03-08 15:48 | yorik | Fixed in Version | => 0.17 |
