| 0002793 | FreeCAD | Feature | public | 2016-11-25 08:11 | 2019-01-17 14:39 |
| Reporter | herrdeh | Assigned To | wmayer | ||
| Summary | 0002793: "tube" as basic solid | ||||
| Description | I hardly ever use the "torus" or the "prism" but spend lots of time with creating all kinds of tubes out of two cylinders. Wouldnt it be nice to have a "tube" basic solid? - Inner, outer diameter, height - and we are done. | ||||
This is a nice feature to have! |
But that is the problem : a tube is *not* a primitive. The Part workbench primitives are not intended to create complex shapes, only geometric primitives. A tube could only be added to a special purpose workbench, but definitely not to the Make Primitives utility. BTW using a sketch with two concentric circles and making a PartDesign Pad you can create a tube, and you can resize its dimensions quite quickly. Or with some python scripting you can create your own parametric objects. |
https://github.com/FreeCAD/FreeCAD/commit/552ed9eab2aa615f8e9744608236aa48893327dd |
| 2016-11-25 08:11 | herrdeh | New Issue | |
| 2016-11-26 15:16 | hinckel | Note Added: 0007489 | |
| 2016-11-26 17:23 | normandc | Note Added: 0007490 | |
| 2017-09-15 10:37 | wmayer | Target Version | => 0.17 |
| 2017-11-21 16:12 | Kunda1 | Target Version | 0.17 => 0.18 |
| 2019-01-17 14:39 | wmayer | Assigned To | => wmayer |
| 2019-01-17 14:39 | wmayer | Status | new => closed |
| 2019-01-17 14:39 | wmayer | Resolution | open => fixed |
| 2019-01-17 14:39 | wmayer | Fixed in Version | => 0.18 |
| 2019-01-17 14:39 | wmayer | Note Added: 0012451 |
