0002797GCSBugpublic2018-06-09 16:01
Reporterwmayer Assigned Toabdullah
Status closedResolutionfixed
Product Version0.16
Target Version0.17
Summary0002797: Slots may explode when applying coindicences with symmetric points
DescriptionFor more information see: http://forum.freecadweb.org/viewtopic.php?f=13&t=18743&p=146197#p146197
Tagsconstraints, Solver
2016-11-28 20:45
administrator   ~0007496
See also http://forum.freecadweb.org/viewtopic.php?f=13&t=18757&p=146411#p146411
2016-11-28 20:46
administrator
2797.fcstd (6,881 bytes)
abdullah
2017-05-22 17:05
manager   ~0009085
The symmetry constraint is rightly solved. However, when one tries to make a coincident between the circle and the center of the left arc of the slot, FC fails to solve it.
However, removing the point on object constraint on that circle (which is redundant in view of the symmetry constraint), allows the coincident to work and FC rightly solves it.
@kunda1
This to be tagged with the "solver" tag.
2017-05-22 18:59
administrator   ~0009087
Done, thanks Abdullah!
abdullah
2018-06-09 08:49
manager   ~0011376
@wmayer
I think this ticket is resolved in current master. I think it was solved by the redundancy detection recently merged.
Now when you load the sketch, it complains about a redundancy. You remove this redundancy and you can make the center of the arc and the center of the circle coincident and arrive to a fully constraint sketch without any problems.
2018-06-09 16:01
administrator   ~0011389
It looks like this issues bas been resolved with v0.17. According to my step-by-step instructions I could reproduce with v0.16 but not with v0.17 any more.
2016-11-27 15:29 wmayer New Issue
2016-11-28 20:45 wmayer Note Added: 0007496
2016-11-28 20:46 wmayer File Added: 2797.fcstd
2017-02-15 06:08 kkremitzki Target Version => 0.17
2017-05-22 17:05 abdullah Note Added: 0009085
2017-05-22 18:59 Kunda1 Tag Attached: Solver
2017-05-22 18:59 Kunda1 Note Added: 0009087
2017-09-27 12:27 Kunda1 Tag Attached: constraints
2017-12-13 15:20 Kunda1 Project Sketcher => GCS
2018-06-09 08:49 abdullah Assigned To => abdullah
2018-06-09 08:49 abdullah Status new => feedback
2018-06-09 08:49 abdullah Note Added: 0011376
2018-06-09 16:01 wmayer Status feedback => assigned
2018-06-09 16:01 wmayer Resolution open => fixed
2018-06-09 16:01 wmayer Note Added: 0011389
2018-06-09 16:01 wmayer Status assigned => closed
