0002804SketcherBugpublic2017-08-13 15:34
Reportertomkcook Assigned Toabdullah
Status closedResolutionfixed
Platformx64OSWindowsOS Version10
Product Version0.17
Target Version0.17Fixed in Version0.17
Summary0002804: Mirroring sketches misses some constraints
DescriptionCreating a mirror of a sketch does not copy all constraints. At least angle constraints are not copied.
Steps To ReproduceCreate a fully-constrained sketch including an angle constraints.
Close the sketch.
Select Sketch -> Mirror Sketch.
Open the mirrored sketch - it is under-constrained.
Additional InformationIf someone can point me to the relevant bit of the source, I'll fix this.
2017-01-16 09:48
administrator   ~0007817
Forum thread: http://forum.freecad.org/viewtopic.php?f=10&t=19942
kkremitzki
2017-02-15 06:06
administrator
bug2804.fcstd (9,261 bytes)
kkremitzki
2017-02-15 06:07
administrator   ~0008304
Confirmed in:
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10064 (Git)
Build type: None
Hash: d7ed8c4383f394f64dd9314eefa00efae02fb32f
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
jnxd
2017-02-25 19:40
developer   ~0008435
@tomcook, here the command to mirror sketch is defined. The task creation and then the mirror creation should be happening somewhere in the activated() method. Hope it helps.
jnxd
2017-02-25 19:41
developer   ~0008436
@tomkcook ^^
2017-04-26 12:16
administrator   ~0008778
Fix committed by Abdullah in c:FreeCAD:b6833e88: ( FreeCAD Pull Request 692 )
Resolving ticket.
Bugtracker note: please attach changeset commit to ticket before closing
2016-12-01 11:36 tomkcook New Issue
2017-01-16 09:48 Kunda1 Note Added: 0007817
2017-02-15 06:06 kkremitzki File Added: bug2804.fcstd
2017-02-15 06:06 kkremitzki Status new => confirmed
2017-02-15 06:06 kkremitzki Target Version => 0.17
2017-02-15 06:07 kkremitzki Note Added: 0008304
2017-02-25 19:40 jnxd Note Added: 0008435
2017-02-25 19:41 jnxd Note Added: 0008436
2017-03-11 14:25 jnxd Tag Attached: #lowhangingfruit
2017-04-26 12:13 Kunda1 Tag Detached: #lowhangingfruit
2017-04-26 12:13 Kunda1 Assigned To => abdullah
2017-04-26 12:13 Kunda1 Status confirmed => assigned
2017-04-26 12:16 Kunda1 Status assigned => resolved
2017-04-26 12:16 Kunda1 Resolution open => fixed
2017-04-26 12:16 Kunda1 Fixed in Version => 0.17
2017-04-26 12:16 Kunda1 Note Added: 0008778
2017-04-28 11:59 Kunda1 Note Edited: 0008778
2017-04-28 12:00 Kunda1 Note Edited: 0008778
2017-08-13 15:34 Kunda1 Status resolved => closed
