| 0002815 | Sketcher | Bug | public | 2016-12-06 15:14 | 2017-05-01 00:29 |
| Reporter | Sterna | Assigned To | |||
| Platform | Macbook Pro late 2011 | OS | OS X | OS Version | 10.11.6 |
| Summary | 0002815: Default shortcut (shift + d) for "Constrain distance" has conflict | ||||
| Description | One of the most useful constraint in the sketcher is the Distance constraint. The keyboard shortcut for this is (and has been for a while) shift+D. Recently, the function "Docked" has been assigned to the same shortfuct, which conflicts, and hinders the function. Please change the default shortcut for Docked to something else. | ||||
| Steps To Reproduce | Open Sketcher Draw a line Press shift+D (nothing happens, since windows are docked be default) | ||||
| Additional Information | Workaround: Using the Customize menu, re-assign the keyboard shortcut for Docked (under Standard view) to something else. | ||||
| Tags | keyboard, shortcuts | ||||
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20323 |
@Sterna in the future please first post this as a forum thread feature request before opening a ticket. This is a guideline stated in http://forum.freecadweb.org/viewtopic.php?f=3&t=5236 To make your argument heard and discussed please participate in the forum thread I opened for you ^ Thanks. |
@yorik is this still the case in 0.17 ? If so this FR sounds reasonable. |
Per the forum thread this is a non-issue in current 0.17 master. |
| 2016-12-06 15:14 | Sterna | New Issue | |
| 2017-01-28 20:58 | Kunda1 | Note Added: 0008065 | |
| 2017-02-04 10:25 | Kunda1 | Tag Attached: keyboard | |
| 2017-02-04 10:25 | Kunda1 | Tag Attached: shortcuts | |
| 2017-02-04 10:28 | Kunda1 | Summary | Default shortcut for "Constrain distance" has conflict => Default shortcut (shift + d) for "Constrain distance" has conflict |
| 2017-02-04 10:33 | Kunda1 | Note Added: 0008209 | |
| 2017-02-04 10:33 | Kunda1 | Status | new => feedback |
| 2017-04-29 11:33 | Kunda1 | Note Added: 0008820 | |
| 2017-05-01 00:29 | Kunda1 | Status | feedback => closed |
| 2017-05-01 00:29 | Kunda1 | Resolution | open => fixed |
| 2017-05-01 00:29 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-05-01 00:29 | Kunda1 | Note Added: 0008837 |
