| 0002826 | Arch | Bug | public | 2017-01-02 00:14 | 2018-01-12 16:09 |
| Reporter | ruchg | Assigned To | yorik | ||
| Platform | Linux | OS | Fedora 25 | OS Version | 4.8.15-300.fc25. |
| Summary | 0002826: When adding Circular profiles to profile.csv, instructions are incorrect | ||||
| Description | There are a couple of errors in the profile.csv file that impede the user from entering their own circular profiles. First there is a copy and paste error. #Data structure: #Category, Name, Profile class, geometric data... #Possible profile classes are: #C=Circular tube #H= H- or I-profile #R= Rectangular #RH= Rectangular hollow #U= U-profile ########################################### #Circular tube #Category,Name,H,Outside diameter,Thickness CTH,CTH423,C,42.4,3.2 In the last comment, the H profile class should be a C Further the "Outside diameter" needs to be changed to "Outside radius," and "Thickness" should be changed to "half wall thickness." This is the only profile I've looked at. I've noticed that the rectangular 2x4in profile is the size of a kiln dried wooden stud 1.5x3.5in. It might be wise to add some sort of alert that these are nominal dried wood dimensions and not as stated. | ||||
| Steps To Reproduce | Using a text editor, and the correct permissions, edit file profile.csv and add two circular profiles as below. CTH,10x2mm_Pipe,C,10,2 CTH,10x2mm_PipeTry1,C,5,1 Save and exit. Start FreeCAD and a new drawing Switch to Arch Workbench, select xy plane Select Structure, Category CTH and the 10x2mm_Pipe preset. Place at X=Y=Z=0 Click on an empty area of the geometry window to clear the highlight Select Structure, Category CTH and the 10x2mm_PipeTry1 preset. Place at X=30; Y=Z=0 Start Drawing Dimensioning Workbench, and add an A3 Landscape (plain) form Highlight both Structures and Insert View into active drawing. Select both Views in the Page and move to X=Y=100 Create circular dimensions on the 4 ID&ODs Create linear dimensions on the two thicknesses The first gives a 20mm OD and a 4mm wall. The second gives a 10mm OD and a 2mm wall. | ||||
| Additional Information | Alternately the issue could be addressed in the ArchProfile.py file. If so, then there are a couple of minor errors that could be fixed there as well. class _ProfileC(_Profile): '''A parametric circular tubeprofile. Profile data: [Outside diameter, Inside diameter]''' a space is needed to separate tube and profile class _ProfileU(_Profile): '''A parametric H or I beam profile. Profile data: [width, height, web thickness, flange thickness] (see http://en.wikipedia.org/wiki/I-beam forreference)''' The comment is probably a cut and paste error and was not updated for the c-channel If you are looking for a wikipedia article for this: https://en.wikipedia.org/wiki/Structural_channel | ||||
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19992 |
Will look into it! |
Fixed in https://github.com/FreeCAD/FreeCAD/commit/a8ab24abaee3a708e4d9f4358a0a12751aa6886b |
| 2017-01-02 00:14 | ruchg | New Issue | |
| 2017-01-17 20:46 | Kunda1 | Note Added: 0007855 | |
| 2017-05-25 05:53 | Kunda1 | Project | FreeCAD => Arch |
| 2017-07-19 14:02 | yorik | Assigned To | => yorik |
| 2017-07-19 14:02 | yorik | Status | new => assigned |
| 2017-07-19 14:02 | yorik | Note Added: 0009784 | |
| 2018-01-12 16:08 | yorik | Note Added: 0010745 | |
| 2018-01-12 16:09 | yorik | Status | assigned => closed |
| 2018-01-12 16:09 | yorik | Resolution | open => fixed |
