| 0002832 | FreeCAD | Feature | public | 2017-01-07 15:45 | 2017-08-13 15:32 |
| Reporter | ruchg | Assigned To | yorik | ||
| Platform | Linux | OS | Fedora 25 | OS Version | 4.8.15-300 |
| Summary | 0002832: Dimension polish | ||||
| Description | I believe that more dimension properties need to be made available in Edit --> Preferences --> Draft --> Text and Dimensions. For example the Property window View tab lists Decimals, however it is not available in the Preferences window. This forces the user to select multiple dimensions and set decimals en mass to the desired value. If the setting was available in Preferences this would not be necessary. The user may one day be working on a house drawing in millimeters and doesn't need decimals and on the next day working on a clock drawing where he needs all the precision he can get. Another property might be Line Width that may change from day to day as the user moves from house drawings to watch parts. It would also be easier if the two lists used the same names for the same things. I've included a line by line listing for illustration. Preferences View Tab Dimension Properties Base Y Display Mode Y Visibility Draft Y Y Arrow Size Y Arrow style Y Arrow Type No Y Decimals Y Y Ext Lines No Y Flip Arrows Y Font family Y Font Name Y Y Font Size No Y Line Color No Y Line Width No Y Override No Y Pattern No Y Pattern Size Y Y Show Unit No Y Text Position Y Y Text Spacing | ||||
| Additional Information | I've enclosed a spreadsheet table which better shows the table above. | ||||
The dimension decimals are there already, in the Draft General tab. Indeed that setting should be moved to the dimensions tab. The line width takes the general line width setting of Draft, that applies to all Draft objects. It is settable in the preferences as well as on the toolbar... |
@yorik looks like OPs spreadsheet is missing. Is it needed for implementing this feature? |
@Kunda1 I don't think so, I think it contained the same thing that is on the OP Actually the things I wanted to do in this issue are done, from my point of view... I didn't understand well the problem with 'Line Width' and the rest, @ruchg ? |
@ruchg please respond |
Resolving since op hasn't responded |
Closing |
FreeCAD: master 162c74c2 2017-01-07 17:20:58 Details Diff |
Draft: Moved dimension decimals preference setting to the dimension preferences tab - issue 0002832 |
Affected Issues 0002832 |
| mod - src/Mod/Draft/Resources/ui/preferences-draft.ui | Diff File | ||
| mod - src/Mod/Draft/Resources/ui/preferences-drafttexts.ui | Diff File | ||
| 2017-01-07 15:45 | ruchg | New Issue | |
| 2017-01-07 15:45 | ruchg | File Added: FreeCADdimensioningPolish.ods | |
| 2017-01-07 16:17 | yorik | Note Added: 0007568 | |
| 2017-01-07 16:17 | yorik | Assigned To | => yorik |
| 2017-01-07 16:17 | yorik | Status | new => assigned |
| 2017-01-07 16:21 | yorik | Changeset attached | => FreeCAD Master master 162c74c2 |
| 2017-05-02 11:13 | Kunda1 | Note Added: 0008849 | |
| 2017-05-02 23:23 | yorik | Note Added: 0008873 | |
| 2017-05-27 19:19 | Kunda1 | Status | assigned => feedback |
| 2017-05-27 19:19 | Kunda1 | Note Added: 0009171 | |
| 2017-07-03 21:13 | Kunda1 | Status | feedback => resolved |
| 2017-07-03 21:13 | Kunda1 | Resolution | open => fixed |
| 2017-07-03 21:13 | Kunda1 | Note Added: 0009658 | |
| 2017-07-03 21:14 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-08-13 15:32 | Kunda1 | Status | resolved => closed |
| 2017-08-13 15:32 | Kunda1 | Note Added: 0009906 |
