| 0002833 | Expressions | Bug | public | 2017-01-07 21:49 | 2018-09-12 15:44 |
| Reporter | psolyca | Assigned To | wmayer | ||
| Summary | 0002833: [Spreadsheet] Keyboard events are sent to the wrong viewprovider | ||||
| Description | When going to a spreadsheet by the tab, the spreadsheet is not activated and all commands are sent to the previous tab. eivindkvedalen sum up saying keyboard events are sent to the wrong viewprovider. Here is the forum thread : http://forum.freecadweb.org/viewtopic.php?p=152236 | ||||
| Steps To Reproduce | Create a spreadsheet Enter some text, parameters and alias - for example text (A1) : Radius, parameter (B1) : 10, alias (B1) : R Create a body Create an empty sketch Go back to the spreadsheet, select a text -> you can not erase your text Close and reopen the spreadsheet (or force recompute of spreadsheet), select your text -> you can erase your text Draw something on your sketch - for example a circle Go back to the spreadsheet, select a text -> you can not erase your text and sometimes the sketch is deleted Close and reopen the spreadsheet (or force recompute of spreadsheet), select your text -> you can erase your text Go back to your sketch, use a parameter from your spreadsheet - an expression for a radius constraint on the circle : Spreadsheet.R Go back to the spreadsheet, select a text -> you can not erase your text and sometimes the sketch is deleted Close and reopen the spreadsheet (or force recompute of spreadsheet), select a text not the parameter -> error message "The following, referencing objects might break. Are you sure you want to continue ? Sketch" | ||||
| Tags | spreadsheet | ||||
The trick is to use handle QEvent::ShortcutOverride inside SheetTableView which tells Qt not to invoke the shortcut that is assigned the "Del" key but instead let SheetTableView handle key events. https://github.com/FreeCAD/FreeCAD/commit/ac66048b8bb740a185a65f0b5135f75b6cc09ef0 |
| 2017-01-07 21:49 | psolyca | New Issue | |
| 2017-01-08 22:48 | eivindkvedalen | Assigned To | => eivindkvedalen |
| 2017-01-08 22:48 | eivindkvedalen | Status | new => assigned |
| 2017-05-01 23:24 | Kunda1 | Tag Attached: spreadsheet | |
| 2017-12-13 15:27 | Kunda1 | Project | FreeCAD => Expressions |
| 2017-12-13 15:32 | Kunda1 | Summary | Keyboard event and Spreadsheet => [Spreadsheet] Keyboard events are sent to the wrong viewprovider |
| 2017-12-13 15:32 | Kunda1 | Description Updated | |
| 2018-09-12 15:44 | wmayer | Assigned To | eivindkvedalen => wmayer |
| 2018-09-12 15:44 | wmayer | Status | assigned => closed |
| 2018-09-12 15:44 | wmayer | Resolution | open => fixed |
| 2018-09-12 15:44 | wmayer | Fixed in Version | => 0.18 |
| 2018-09-12 15:44 | wmayer | Note Added: 0011719 |
