| 0002834 | FreeCAD | Bug | public | 2017-01-08 05:38 | 2017-07-11 20:10 |
| Reporter | GaryScottMartin | Assigned To | Kunda1 | ||
| Platform | X64 | OS | ArchLinux/KDE/Openbox/Plasma5 | OS Version | Current |
| Summary | 0002834: SegFault/CoreDump on Start | ||||
| Description | FreeCAD installed normally by pacman ("sudo pacman -Syu freecad"). Starting from menu results in splash screen with "Initalizing ..." messages scrolling through the bottom of the window. That disappears and the FreeCAD SegFaults/CoreDumps immediately. Starting from the console produces the text in the Additional Info block below. I have also included the log file below along with a stack trace from gdb. | ||||
| Steps To Reproduce | Same behavior every time. Repeated at least a dozen times so far. | ||||
| Additional Information | The console output, log file, and gdb stack trace are concatenated into the attached file. | ||||
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=4&t=19797 |
A few ideas: 1. Does it work to run the command line version, i.e. freecadcmd? If yes, what happens when e.g. doing
2. It's funny that all these CSF_ environment variables are set. Especially CSF_GraphicShr has caused problems in the past if not set correctly. Does unsetting CSF_GraphicShr fix the crash? 3. This comes up when using the debugger: warning: Cannot call inferior functions, Linux kernel PaX protection forbids return to non-executable pages! Is this debugger related? 4. the debugger output only shows 50 calls. Are there not more? From the 50 calls it's not clear where inside FreeCAD the crash occurs. |
1. Yes, freecadcmd appears to start normally and presents a Python prompt ">>>"
results in no error and same prompt back in response. (see attached text file from 2017-01-13 for console output)2. Unsetting CSF_GraphicShr appears to have no impact, behavior appears unchanged as far I can see. (see attached text file from 2017-01-13 for console output, log, and gdb output) 3. Not sure what this means, I'm a newb to gdb. Most of my coding experience is FORTRAN & assembler on Interdata/Perkin Elmer/Concurrent OS/32 minicomputers 30+ years ago. 4. The gdb output in the two text files is complete. gdb only lists 50 calls and appears to completes the bt command without complaint. |
@GaryScottMartin can you post your Help > About FreeCAD > 'Copy to clipboard' please? Thanks |
Learned enough Python just now to open the main window from the command line. Help > About > Copy to Clipboard produced the following: OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.Unknown Build type: Release Python version: 2.7.13 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.9.1 |
I spoke too soon. I was able to get the GUI to open once, but it does not open anymore. The following was cut from interpreter after starting freecadcmd:
No apparent error, but GUI did not open. |
Not sure of the significance of this but produced the following:
The GUI reappeared after this, as well. |
>No apparent error, but GUI did not open. You may have to execute this at the end: |
@GaryScottMartin ping ^ |
@GaryScottMartin please respond to 0002834:0007935 |
First the good news: update today included FreeCAD, Plasma/KDE, and Linux Kernel. After reboot FreeCAD starts normally both the application launcher and from the console. Console output here: <quote> [gary@tehachapimtn ~]$ freecad FreeCAD 0.16, Libs: 0.16RUnknown © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## [gary@tehachapimtn ~]$ </quote> However, I can no longer get the GUI to start from the command. Output for that attempt is here: <quote> [gary@tehachapimtn ~]$ freecad FreeCAD 0.16, Libs: 0.16RUnknown © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## [gary@tehachapimtn ~]$ freecadcmd FreeCAD 0.16, Libs: 0.16RUnknown (c) Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## [FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>] >>> import FreeCAD >>> import FreeCADGui >>> import Part >>> FreeCADGUI Traceback (most recent call last): File "<stdin>", line 1, in <module> NameError: name 'FreeCADGUI' is not defined >>> FreeCADGui.exec_loop() Traceback (most recent call last): File "<stdin>", line 1, in <module> RuntimeError: Must construct a QApplication before a QPaintDevice >>> help("modules") Please wait a moment while I gather a list of all available modules... 10:22:55 PM: Warning: Mismatch between the program and library build versions detected. The library used 3.0 (wchar_t,compiler with C++ ABI 1010,wx containers,compatible with 2.8), and wxPython used 3.0 (wchar_t,compiler with C++ ABI 1009,wx containers,compatible with 2.8). /usr/lib/python2.7/site-packages/matplotlib/cbook.py:136: MatplotlibDeprecationWarning: The matplotlib.delaunay module was deprecated in version 1.4. Use matplotlib.tri.Triangulation instead. warnings.warn(message, mplDeprecation, stacklevel=1) (freecadcmd:1491): Gtk-WARNING **: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version (freecadcmd:1491): Gtk-WARNING **: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version (freecadcmd:1491): Gtk-WARNING **: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version /usr/lib/python2.7/site-packages/quodlibet/browsers/_base.py:12: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded. from gi.repository import Gtk, GObject, GLib, Pango E: 0.353: util.importhelper.load_dir_modules: thread.py:14:<module>: ImportError: python-futures is missing: ImportError('No module named concurrent.futures',) /usr/lib/python2.7/site-packages/quodlibet/ext/songsmenu/fingerprint/__init__.py:9: PyGIWarning: Gst was imported without specifying a version first. Use gi.require_version('Gst', '1.0') before import to ensure that the right version gets loaded. from gi.repository import Gtk, Gst Arch libKF5GAPICalendar libgailutil-3 libprocps ArchAxis libKF5GAPIContacts libgamin-1 libprotobuf ArchBuilding libKF5GAPICore libgbm libprotobuf-lite ArchCommands libKF5GAPIDrive libgc libprotoc [....] </quote> Entering produced the following error:<quote> Traceback (most recent call last): File "<stdin>", line 1, in <module> RuntimeError: Must construct a QApplication before a QPaintDevice </quote> Previously would result in the GUI starting after importing FreeCADGui, but it no longer does. |
> RuntimeError: Must construct a QApplication before a QPaintDevice You first mus call FreeCADGui.showMainWindow() which constructs the QApplication instance. |
Issue resolved. FreeCADGui starts normally from Application Launcher, Console, & freecadcmd. Thank you, very much. |
Resolving and keeping open unless devs decide differently |
| 2017-01-08 05:38 | GaryScottMartin | New Issue | |
| 2017-01-08 05:38 | GaryScottMartin | File Added: BugReport--martin-gary-s--2017-0107.txt | |
| 2017-01-11 18:50 | Kunda1 | Note Added: 0007640 | |
| 2017-01-11 20:24 | wmayer | Note Added: 0007648 | |
| 2017-01-11 20:37 | Kunda1 | Status | new => feedback |
| 2017-01-13 19:14 | GaryScottMartin | File Added: BugReport--martin-gary-s--2017-0113.txt | |
| 2017-01-13 19:30 | GaryScottMartin | Note Added: 0007725 | |
| 2017-01-13 19:30 | GaryScottMartin | Status | feedback => new |
| 2017-01-20 21:10 | Kunda1 | Note Added: 0007896 | |
| 2017-01-20 21:10 | Kunda1 | Status | new => feedback |
| 2017-01-21 00:56 | GaryScottMartin | Note Added: 0007899 | |
| 2017-01-21 00:56 | GaryScottMartin | Status | feedback => new |
| 2017-01-21 01:10 | GaryScottMartin | Note Added: 0007900 | |
| 2017-01-21 01:17 | GaryScottMartin | Note Added: 0007901 | |
| 2017-01-23 22:29 | wmayer | Note Added: 0007935 | |
| 2017-01-23 23:13 | Kunda1 | Status | new => feedback |
| 2017-01-29 15:18 | Kunda1 | Note Added: 0008081 | |
| 2017-02-06 05:27 | Kunda1 | Note Added: 0008224 | |
| 2017-02-08 06:39 | GaryScottMartin | Note Added: 0008234 | |
| 2017-02-08 06:39 | GaryScottMartin | Status | feedback => new |
| 2017-02-08 12:11 | wmayer | Note Added: 0008235 | |
| 2017-02-08 12:37 | Kunda1 | Status | new => feedback |
| 2017-02-11 01:59 | GaryScottMartin | Note Added: 0008271 | |
| 2017-02-11 01:59 | GaryScottMartin | Status | feedback => new |
| 2017-02-11 02:00 | GaryScottMartin | Tag Attached: #tobeclosed | |
| 2017-02-13 16:26 | Kunda1 | Note Added: 0008286 | |
| 2017-02-13 16:26 | Kunda1 | Status | new => resolved |
| 2017-02-13 16:26 | Kunda1 | Resolution | open => fixed |
| 2017-02-13 16:26 | Kunda1 | Assigned To | => Kunda1 |
| 2017-02-17 18:03 | wmayer | Status | resolved => closed |
| 2017-02-17 18:03 | wmayer | Resolution | fixed => no change required |
| 2017-07-11 20:10 | Kunda1 | Tag Detached: #tobeclosed |
