| 0002845 | Part | Bug | public | 2017-01-12 19:11 | 2018-10-19 14:56 |
| Reporter | Gadgeteering | Assigned To | chrisb | ||
| Platform | OSX | OS | Sierra | OS Version | 10.12.1 |
| Summary | 0002845: Part fusion fails when trying to fusion 10 offset parts into 1 | ||||
| Description | When trying to fusion 10 offset parts into one the fusion fails. I can reproduce this fault all the time | ||||
| Steps To Reproduce | 1) Open attached file: Hoverlft Fan Mk2.FCStd 2) select all the Blade objects (Blade-Blade009) 3) and then select union from the Parts menu, Result: FC will fail to fusion these objects correctly. Note: I have found a work around by fusing blade objects in pairs and then in-turn fusing those fusions and then fusing this fusions, I can reach my original objective. | ||||
| Tags | fusion, Part | ||||
I have just tried version 0.17 and it produces the same fault |
This is a very poorly written bug report. In the "Steps to reproduce", you are supposed to list all the steps required to reproduce the problem, not simply say "I can reproduce this fault all the time". What you need to describe and detail is HOW. You should also have read the READ THIS BEFORE REPORTING link before doing anything. This link is under the ISSUES menu, right above the "REPORT ISSUE" link you clicked to report this issue, so you have no excuse for not seeing it. The "Read this" link explain that you should always talk about your issue on the FreeCAD forum first so we can ensure the quality of bug reports and avoid duplicates. |
To reproduce the bug select all the Blade objects (Blade-Blade009) and then select union from the Parts menu, free cad will fail to fusion these objects correctly. I have found a work around by fusing blade objects in pairs and then in-turn fusing those fusions and then fusing this fusions, I can reach my original objective. |
@Gadgeteering please add the contents of Help > About FreeCAD as well. Note: I also edited the ticket to demonstrate a more ideal way to write a bug report. Thanks. |
On the OS X version of the Freecad the contents data is at Freecad > About FreeCAD Info below: OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6706 (Git) Build type: Release Branch: tag: 0.16.6706 Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0 Python version: 2.7.11 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.17 |
Please continue the discussion in the forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=20000 |
Tagged 'Part' so that it would be moved to new Part category |
Not sure why moving the report switched the category... |
@Gadgeteering please test with the latest 0.18dev Below is a response from DeepSOIC on the forum concerning this ticket. He cannot reproduce the issue: https://forum.freecadweb.org/viewtopic.php?p=263160#p263160 |
The issue does not occur with current 0.18. OS: macOS High Sierra (10.13) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14957 (Git) Build type: Release Branch: (HEAD detached at 22513600d) Hash: 22513600ddc11a8d0d392f67225d443b7dc2e5bb Python version: 2.7.15 Qt version: 5.11.2 Coin version: 4.0.0a OCC version: 7.2.0 Locale: German/Germany (de_DE) |
| 2017-01-12 19:11 | Gadgeteering | New Issue | |
| 2017-01-12 19:11 | Gadgeteering | File Added: Hoverlft Fan Mk2.FCStd | |
| 2017-01-12 19:11 | Gadgeteering | Tag Attached: fusion | |
| 2017-01-12 20:01 | Gadgeteering | Note Added: 0007683 | |
| 2017-01-14 17:13 | normandc | Note Added: 0007766 | |
| 2017-01-14 21:36 | Kunda1 | Status | new => feedback |
| 2017-01-15 07:48 | Gadgeteering | Note Added: 0007783 | |
| 2017-01-15 07:48 | Gadgeteering | Status | feedback => new |
| 2017-01-15 12:22 | Kunda1 | Note Added: 0007784 | |
| 2017-01-15 12:26 | Kunda1 | Priority | high => normal |
| 2017-01-15 12:26 | Kunda1 | Severity | major => minor |
| 2017-01-15 12:26 | Kunda1 | Description Updated | |
| 2017-01-15 12:26 | Kunda1 | Steps to Reproduce Updated | |
| 2017-01-15 12:27 | Kunda1 | Note Edited: 0007784 | |
| 2017-01-15 12:28 | Kunda1 | Summary | When fusion offsets => Part fusion fails when trying to fusion 10 offset parts into 1 |
| 2017-01-15 18:10 | Gadgeteering | Note Added: 0007800 | |
| 2017-01-18 01:32 | Kunda1 | Note Added: 0007860 | |
| 2017-05-02 22:08 | Kunda1 | Tag Attached: Part | |
| 2017-05-02 22:10 | Kunda1 | Note Added: 0008869 | |
| 2017-06-17 23:44 | normandc | Project | PartDesign => Part |
| 2017-06-17 23:44 | normandc | Category | Bug => General |
| 2017-06-17 23:46 | normandc | Category | General => Bug |
| 2017-06-17 23:46 | normandc | Note Added: 0009432 | |
| 2018-10-19 13:43 | Kunda1 | Target Version | => 0.18 |
| 2018-10-19 13:58 | Kunda1 | Status | new => feedback |
| 2018-10-19 13:58 | Kunda1 | Note Added: 0012073 | |
| 2018-10-19 13:58 | Kunda1 | Note Edited: 0012073 | |
| 2018-10-19 14:56 | chrisb | Assigned To | => chrisb |
| 2018-10-19 14:56 | chrisb | Status | feedback => closed |
| 2018-10-19 14:56 | chrisb | Resolution | open => no change required |
| 2018-10-19 14:56 | chrisb | Fixed in Version | => 0.18 |
| 2018-10-19 14:56 | chrisb | Note Added: 0012074 |
