| 0002848 | Path | Bug | public | 2017-01-12 21:48 | 2017-03-13 23:52 |
| Reporter | mlampert | Assigned To | mlampert | ||
| Summary | 0002848: HoldingTags dressup should not approximate all arcs with segments | ||||
| Description | Once the HoldingTags dressup is applied to a Contour, arcs of the same get approximated through a lot of segments, regardless if they are affected by the dressup or not. | ||||
| Steps To Reproduce | Create Contour of a shape. Set ShowNodes to true Note that each arc is described by 3 nodes Apply dressup: Path->Path Dressup->HoldingTags Dressup Set ShowNodes to true Note that each arc has a myriad of nodes on it - and no more center node. | ||||
FreeCAD: master e76333f3 2017-01-13 02:39:23 Details Diff |
Fixed segmentation of xy-plane arcs, made # segments factor a property. |
Affected Issues 0002848 |
| mod - src/Mod/Path/PathScripts/PathDressupHoldingTags.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathGeom.py | Diff File | ||
FreeCAD: master bbd606ac 2017-01-13 14:21:33 Committer: GitHub Details Diff |
Merge pull request 0000434 from mlampert/HoldingTagArcs Path: Holding tags fixes issue 2848 |
| 2017-01-12 21:48 | mlampert | New Issue | |
| 2017-01-12 21:48 | mlampert | Status | new => assigned |
| 2017-01-12 21:48 | mlampert | Assigned To | => mlampert |
| 2017-01-13 14:09 | wmayer | Changeset attached | => FreeCAD Master master e76333f3 |
| 2017-01-13 14:09 | wmayer | Status | assigned => closed |
| 2017-01-13 14:09 | wmayer | Resolution | open => fixed |
| 2017-01-13 14:09 | wmayer | Fixed in Version | => 0.17 |
| 2017-03-13 23:52 | Kunda1 | Changeset attached | => FreeCAD master bbd606ac |
