0002850PathBugpublic2017-04-29 12:17
Reportersebste Assigned Tosliptonic
Status closedResolutionfixed
PlatformLinuxOSMint LMDEOS VersionBetsy
Product Version0.17
Target Version0.17Fixed in Version0.17
Summary0002850: PATH: Changed Tool parameters are not updated in operations
DescriptionIf an operation has been created, based on a tool in the tool table, and the tools properties are changed in the tool editor, the tool parameters in the existing operations are not changed.
Steps To ReproduceCreate a path job object
create tool controler or select tool in existing tool controler
add pocket operation
double click tool controler, to see cylindrical representation of tool
got to tool table editor
doubleclick the tool selected in the job
change diameter to extreme value, close tool editor
-> Paths remian unchanged and do not reflect the changed tool diameter
doubleclick on tool controller
-> cylindrical representation remains unchanged
2017-01-13 21:37
administrator   ~0007731
http://forum.freecad.org/viewtopic.php?f=3&t=2264
sebste
2017-01-13 21:42
reporter   ~0007732
OS: LMDE 2 Betsy
Version: 0.17.9621 (Git)
Hash: 89afaae5535cdc23aff53bcd3ef1d3a936580348
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.7.0
2017-01-18 01:45
administrator   ~0007861
Path sub-forum thread dedicated to this ticket is at http://forum.freecad.org/viewtopic.php?f=15&t=20001
sliptonic
2017-03-20 19:40
manager   ~0008663
The behavior described here is really not a bug. The tool is copied to the local tooltable so changing the properties in the library will have no effect. In upcoming version, the integration between the tool controller and the tool is closer and the panel has an option to 'edit local tool' to change the properties. I'm closing this issue with FreeCAD Pull Request 628
2017-04-29 12:17
administrator   ~0008822
Closing per @sliptonic
See FreeCAD Pull Request 628 for commit details
2017-01-13 21:19 sebste New Issue
2017-01-13 21:37 Kunda1 Note Added: 0007731
2017-01-13 21:42 sebste Note Added: 0007732
2017-01-18 01:45 Kunda1 Note Added: 0007861
2017-03-20 19:40 sliptonic Note Added: 0008663
2017-03-20 19:43 sliptonic Note Edited: 0008663
2017-04-29 12:17 Kunda1 Assigned To => sliptonic
2017-04-29 12:17 Kunda1 Status new => closed
2017-04-29 12:17 Kunda1 Resolution open => fixed
2017-04-29 12:17 Kunda1 Fixed in Version => 0.17
2017-04-29 12:17 Kunda1 Note Added: 0008822
2017-04-29 12:17 Kunda1 Target Version => 0.17
