| 0002851 | Path | Bug | public | 2017-01-13 22:45 | 2017-05-02 22:02 |
| Summary | 0002851: adding additional objects to drilling operation results in duplicate entries. | ||||
| Description | After selecting edges to drill and creating the operation, it presents a dialog if other circular edges of the same diameter were found. If the user agrees to drill these as well, the same dialog appears again and duplicate edges are added to the list. | ||||
| Steps To Reproduce | select 3 holes, click on drill it says "found multiple .... drill them all?" I click OK, I get the same dialog again click OK and I end up with 5 edges in Base | ||||
In part, this happens because a circular hole has two circular edges of the same diameter. When the drilling searches for other holes, it finds both and adds them as candidate locations. It should de-dupe based on center locations but doesn't. I think the drilling operation needs a lot of work and a better UI. For example, perhaps instead of saving the object subelements in the base geometry, we should save the XY coordinates of the drilling location. Instead of having the user select drilling locations, we should prepopulate the list with all drillable locations and diameters and let the user enable/disable. If the user starts by selecting a circle, we could add all locations to the list and present a choice dialog to: 1) enabled only the selected 'hole' 2) enable all other 'holes' of the same diameter. 3) enable all drillable holes in the part. |
Closing manually since mantis source integration didn't get triggered by FreeCAD Pull Request 628 |
| 2017-01-13 22:45 | sliptonic | New Issue | |
| 2017-01-13 22:45 | sliptonic | Status | new => assigned |
| 2017-01-13 22:45 | sliptonic | Assigned To | => sliptonic |
| 2017-01-14 01:14 | mlampert | Relationship added | has duplicate 0002852 |
| 2017-01-14 05:29 | sliptonic | Note Added: 0007752 | |
| 2017-05-02 22:02 | Kunda1 | Status | assigned => closed |
| 2017-05-02 22:02 | Kunda1 | Resolution | open => fixed |
| 2017-05-02 22:02 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-05-02 22:02 | Kunda1 | Note Added: 0008868 |
