| 0002864 | Path | Patch | public | 2017-01-16 22:20 | 2017-02-19 03:09 |
| Reporter | proteus | Assigned To | wmayer | ||
| Platform | Linux | OS | openSUSE | OS Version | Leap 42.1 / 42.2 |
| Summary | 0002864: PathHelix x10 issue on "Step in Z" inputfield and "Step in Radius" | ||||
| Description | After i open the PathHelix UI in the input field "Step in Z" the value is multiplied by 10. In the input filed "Step in Radius" is always the diameter from the tooltable. In the attachment is a patch for this issue. With this patch now the previous_value is propper working. | ||||
| Steps To Reproduce | double klick on PathHelix icon on the left side of the tree. | ||||
| Additional Information | OS: "openSUSE Leap 42.1 (x86_64)" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9661 (Git) Build type: Release Branch: master Hash: 5b5189a8d69378e4216062bab6932978ce303be7 Python version: 2.7.12 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.9.1.oce-0.18-dev | ||||
0003-Add-PathHelix_Fix_for_x10_input_field_issue_017.patch (1,016 bytes)
From a33f71c8b3a76374db2c4c8e731ab9fe3630f7c2 Mon, 16 Jan 2017 12:36:57 +0100
Date: Mon, 16 Jan 2017 12:06:38 +0100
Subject: [PATCH] 0003-Add-PathHelix_Fix_for_x10_input_field_issue_017
Signed-off-by: Michael Kruschinsky <mk@mysmk.de>
diff --git a/src/Mod/Path/PathScripts/PathHelix.py b/src/Mod/Path/PathScripts/PathHelix.py
index db8ecd7..38ac501 100644
--- a/src/Mod/Path/PathScripts/PathHelix.py
+++ b/src/Mod/Path/PathScripts/PathHelix.py
@@ -587,7 +587,9 @@
label = QtGui.QLabel(labelstring)
label.setToolTip(self.obj.getDocumentationOfProperty(property))
- widget.setText(str(getattr(self.obj, property)))
+ # Fix for x10: replace dot with comma.
+ # it's the first fix, i think there was a better one, but it works.
+ widget.setText(str(getattr(self.obj, property)).replace('.', ','))
widget.setToolTip(self.obj.getDocumentationOfProperty(property))
if max:
Posted to the forum https://forum.freecadweb.org/viewtopic.php?f=10&t=20311 @proteus In the future you could use github to submit a Pull Request. It's pretty easy and helps the devs since TravisCI runs on all submitted PRs which include running unit tests. |
@proteus according to chrisb this is not the correct way to fix this issue. See https://forum.freecadweb.org/viewtopic.php?f=10&t=20311#p156599 > This error had been in the Path Workbench as well, see https://forum.freecadweb.org/viewtopic.php?f=10&t=18833&start=10 . The fix with replacing ',' should not be used (it was my first try as well), instead use the unit stuff as is done in PathPocket.py. Since this error occurs here and there in different modules (it has been reported in FEM and ARCH) it should be fixed in the same way or better: The usage of input fields should be everywhere the same in FreeCAD. |
Fix committed in: c:FreeCAD:8a4952044eb592c0f8ad4f60889d63e9ed69ee7b by @lorenz in https://forum.freecadweb.org/viewtopic.php?f=10&t=20311#p159730 |
A confusion occurred since this commit has not been accepted yet. Still a PR FreeCAD Pull Request 523 https://github.com/FreeCAD/FreeCAD/pull/523 |
PR committed that supposedly fixes this ticket. c:FreeCAD:837f2ea: c:FreeCAD:e38d0ad: |
No way to attribute fix to lorenz Also source-integration mantis plugin not working correctly. |
@proteus please test the latest master to verify fix. Thanks |
Hello Kunda1, i have dissabled my patch and test it on the master branch from 017 version. It's working, you can closed this bug. How can i change my loginname from proteus to proteusmk? I need proteusmk while my loginname on github is proteusmk. regards michael |
@proteus thanks for responding. mention something on IRC or gitter.im/FreeCAD/FreeCAD Closing ticket. |
| 2017-01-16 22:20 | proteus | New Issue | |
| 2017-01-16 22:20 | proteus | File Added: 0003-Add-PathHelix_Fix_for_x10_input_field_issue_017.patch | |
| 2017-01-17 00:16 | Kunda1 | Category | Bug => Patch |
| 2017-01-28 13:10 | Kunda1 | Note Added: 0008053 | |
| 2017-02-02 13:11 | Kunda1 | Note Added: 0008169 | |
| 2017-02-02 13:11 | Kunda1 | Status | new => feedback |
| 2017-02-13 21:57 | Kunda1 | Note Added: 0008288 | |
| 2017-02-13 21:58 | Kunda1 | Note Edited: 0008288 | |
| 2017-02-13 21:59 | Kunda1 | Note Edited: 0008288 | |
| 2017-02-13 22:00 | Kunda1 | Status | feedback => resolved |
| 2017-02-13 22:00 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-02-13 22:00 | Kunda1 | Resolution | open => fixed |
| 2017-02-13 22:00 | Kunda1 | Assigned To | => Kunda1 |
| 2017-02-13 22:00 | Kunda1 | Assigned To | Kunda1 => |
| 2017-02-14 13:46 | Kunda1 | Note Added: 0008291 | |
| 2017-02-14 13:46 | Kunda1 | Status | resolved => acknowledged |
| 2017-02-14 13:49 | Kunda1 | Note Edited: 0008291 | |
| 2017-02-14 13:49 | Kunda1 | Resolution | fixed => open |
| 2017-02-14 13:49 | Kunda1 | Fixed in Version | 0.17 => |
| 2017-02-17 23:12 | Kunda1 | Note Added: 0008340 | |
| 2017-02-17 23:14 | Kunda1 | Status | acknowledged => resolved |
| 2017-02-17 23:14 | Kunda1 | Resolution | open => fixed |
| 2017-02-17 23:14 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-02-17 23:14 | Kunda1 | Note Added: 0008341 | |
| 2017-02-18 12:09 | Kunda1 | Note Added: 0008345 | |
| 2017-02-18 13:22 | proteus | Status | resolved => feedback |
| 2017-02-18 13:22 | proteus | Resolution | fixed => reopened |
| 2017-02-18 13:22 | proteus | Note Added: 0008348 | |
| 2017-02-18 13:24 | Kunda1 | Assigned To | => wmayer |
| 2017-02-18 13:24 | Kunda1 | Status | feedback => closed |
| 2017-02-18 13:24 | Kunda1 | Resolution | reopened => fixed |
| 2017-02-18 13:24 | Kunda1 | Note Added: 0008349 | |
| 2017-02-19 03:08 | kkremitzki | Note Edited: 0008340 | |
| 2017-02-19 03:09 | kkremitzki | Note Edited: 0008340 |
