| 0002870 | Path | Bug | public | 2017-01-22 04:00 | 2017-01-28 21:18 |
| Reporter | mlampert | Assigned To | mlampert | ||
| Summary | 0002870: Path unit tests broken by questionable include and not being executed as part of '0' | ||||
| Description | PathDressupHoldingTags imports DraftGui to get access to the todo class - which was used during development. However, DraftGui cannot be included for the unit tests because ti mandates a running Gui. Also there seems to be a '0' unit test target which is run as part of the CI build. This target currently does not include the Path unit tests. In other words, the unit tests currently can't be used to prevent regressions because they are not executed regularly (continuously). | ||||
FreeCAD: master 175d1776 2017-01-28 21:15:51 wwmayer Committer: GitHub Details Diff |
Merge pull request 0000467 from mlampert/path-unit-test-fixes Path: Path unit test fixes issue 0002870 |
Affected Issues 0002870 |
| mod - src/Mod/Path/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathDressupHoldingTags.py | Diff File | ||
| mod - src/Mod/Path/PathTests/PathTestUtils.py | Diff File | ||
| mod - src/Mod/Path/PathTests/TestPathDressupHoldingTags.py | Diff File | ||
| mod - src/Mod/Path/TestPathApp.py | Diff File | ||
| mod - src/Mod/Test/TestApp.py | Diff File | ||
| 2017-01-22 04:00 | mlampert | New Issue | |
| 2017-01-22 04:00 | mlampert | Status | new => assigned |
| 2017-01-22 04:00 | mlampert | Assigned To | => mlampert |
| 2017-01-28 21:16 | Changeset attached | => FreeCAD Master master 175d1776 | |
| 2017-01-28 21:18 | wmayer | Status | assigned => closed |
| 2017-01-28 21:18 | wmayer | Resolution | open => fixed |
| 2017-01-28 21:18 | wmayer | Fixed in Version | => 0.17 |
