| 0002881 | Project Tools & Websites | Feature | public | 2017-01-29 19:45 | 2017-03-13 16:55 |
| Reporter | Kunda1 | Assigned To | kkremitzki | ||
| Priority | none | Severity | tweak | Reproducibility | N/A |
| Summary | 0002881: MantisBT refinements | ||||
| Description | * * * ** .py ** .log * * Add UTF8 support 0002470 * Example:
and Source-Integration shortcuts: see https://github.com/mantisbt-plugins/source-integration/blob/master/Source/lang/strings_english.txt#L108f * Test linking to PRs: FreeCAD Pull Request 498 * Test linking to commits: FreeCAD master 709d2f32 * Test link to diff: FreeCAD master 709d2f32 | ||||
| Additional Information | * Test linking to commits: FreeCAD master 709d2f32 * Test link to diff: FreeCAD master 709d2f32 * Test linking to PRs: FreeCAD Pull Request 498 | ||||
| related to | 0002470 | closed | kkremitzki | MantisBT needs tables converted to UTF8 |
| child of | 0002846 | closed | kkremitzki | MantisBT Proposal: Default template for bug reports |
I dont know what you want me to do here? |
re: make .log and .py viewable as attachments: https://www.mantisbt.org/forums/viewtopic.php?f=3&t=23313 Instructions: In find
and please add 'py' and 'log' to the array |
re: strikethrough in mantisbt: http://mantisbt.org/forums/viewtopic.php?f=3&t=23221#p57645 Instructions: In find
you can add 'del' in there so we can |
Ok both changes above are done
$g_preview_text_extensions = array('', 'txt', 'diff', 'patch' , 'log' , 'py');
$g_html_valid_tags = 'p, li, ul, ol, br, pre, i, b, u, em, strong del';
@yorik, you forgot a comma after
Edit: Re: graphs: > you must have jpgraph in library folder and on linux has trouble with ttf-fonts (check the apache logs). mentioned by @Kirill on https://gitter.im/mantisbt/mantisbt |
oh my bad. Done |
@kunda The notification feature should now be working. The graphs look OK to me in the Summary page as well. I can get that UTF8 conversion done next which just leaves a few others. |
@kkremitzki looks good! Here is some feedback: 1) FreeCAD master 709d2f32 should turn in to a link pointing to FreeCAD github commit 709d2f325 but since it isn't indicates there must be an issue with the source-integration plugin. 2) see attached screenshot which shows the disproportionate table size of activities section in favor of the username icell nstead of the information cell. 3) 4) uncollapsing attachements doesn't seem to open them. |
Hi. I have found an issue with password reset. 1. The reset e-mail comes with some closing html tags (reset_mail.png). 2. The password reset link is wrong. There is a semicolon before the "confirm_hash" parameter instead of an ampersand. It leads to "application error number 200". Cheers, Mateusz |
added https://www.freecadweb.org/wiki/Tracker#MantisBT_Tips_and_Tricks |
One more issue. The code tag parses the html tags inside it. It does not feel right. Unless there is some option to turn it off. Eg.
There are two html _br_ tags inside the _code_ tag. Cheers, Mateusz |
@f3nix the br tags working is intentional, there is a setting to whitelist certain HTML tags, referred to in 0002881:0008101 |
FreeCAD Pull Request 539 |
The email issue was resolved by @Kunda1, the PR link not working is an upstream (and soon to be gone) bug, and the database UTF-8 conversion is a separate issue, so I'm going to close this as resolved. Any subsequent issues should just get created as a new issue in the "Project tools" project and assigned to me. |
I also created 0002911 to track the image previews not working. |
Majority of sub-issues resolved; persistent ones separated into separate issues; new issues with tracker should be created as standalone. |
| 2017-01-29 19:45 | Kunda1 | New Issue | |
| 2017-01-29 19:45 | Kunda1 | Issue generated from: 0002846 | |
| 2017-01-29 19:45 | Kunda1 | Relationship added | child of 0002846 |
| 2017-01-29 19:46 | Kunda1 | Relationship added | related to 0002470 |
| 2017-01-29 19:46 | Kunda1 | Description Updated | |
| 2017-01-29 19:48 | Kunda1 | Description Updated | |
| 2017-01-29 19:48 | Kunda1 | Assigned To | => yorik |
| 2017-01-29 19:48 | Kunda1 | Status | new => assigned |
| 2017-01-30 00:44 | yorik | Note Added: 0008095 | |
| 2017-01-30 02:42 | Kunda1 | Note Added: 0008098 | |
| 2017-01-30 11:59 | Kunda1 | Note Added: 0008100 | |
| 2017-01-30 12:00 | Kunda1 | Note Edited: 0008098 | |
| 2017-01-30 12:00 | Kunda1 | Note Edited: 0008100 | |
| 2017-01-30 12:14 | yorik | Note Added: 0008101 | |
| 2017-01-30 12:14 | yorik | Note Edited: 0008101 | |
| 2017-01-30 20:37 | Kunda1 | Note Added: 0008112 | |
| 2017-01-30 20:40 | Kunda1 | Note Edited: 0008112 | |
| 2017-01-30 20:41 | Kunda1 | Note Edited: 0008112 | |
| 2017-01-31 19:24 | Kunda1 | Description Updated | |
| 2017-01-31 20:48 | yorik | Note Added: 0008138 | |
| 2017-02-03 23:36 | Kunda1 | Description Updated | |
| 2017-02-03 23:37 | Kunda1 | Description Updated | |
| 2017-02-03 23:39 | Kunda1 | Description Updated | |
| 2017-02-03 23:40 | Kunda1 | Description Updated | |
| 2017-02-03 23:41 | Kunda1 | Description Updated | |
| 2017-02-03 23:43 | Kunda1 | Description Updated | |
| 2017-02-03 23:45 | Kunda1 | Description Updated | |
| 2017-02-04 00:19 | Kunda1 | Description Updated | |
| 2017-02-16 08:27 | kkremitzki | Assigned To | yorik => kkremitzki |
| 2017-02-16 10:22 | kkremitzki | Note Added: 0008320 | |
| 2017-02-16 11:04 | Kunda1 | File Added: mantisbt.png | |
| 2017-02-16 11:04 | Kunda1 | Note Added: 0008321 | |
| 2017-02-16 11:05 | Kunda1 | Note Edited: 0008321 | |
| 2017-02-16 11:06 | Kunda1 | Description Updated | |
| 2017-02-16 11:07 | Kunda1 | Note Edited: 0008321 | |
| 2017-02-16 12:09 | kkremitzki | File Added: test.png | |
| 2017-02-19 09:59 | kkremitzki | File Added: fib.py | |
| 2017-02-19 10:07 | kkremitzki | Note Added: 0008362 | |
| 2017-02-19 13:08 | f3nix | File Added: reset_mail.png | |
| 2017-02-19 13:08 | f3nix | Note Added: 0008365 | |
| 2017-02-19 14:57 | Kunda1 | Description Updated | |
| 2017-02-19 16:19 | Kunda1 | Note Added: 0008370 | |
| 2017-02-19 21:30 | f3nix | Note Added: 0008373 | |
| 2017-02-20 03:18 | kkremitzki | Note Added: 0008380 | |
| 2017-02-20 03:53 | Kunda1 | Note Edited: 0008321 | |
| 2017-02-20 20:58 | kkremitzki | Project | FreeCAD => Project Tools & Websites |
| 2017-02-20 22:40 | Kunda1 | Note Added: 0008392 | |
| 2017-02-21 00:29 | kkremitzki | Note Added: 0008393 | |
| 2017-02-21 00:31 | kkremitzki | Note Added: 0008394 | |
| 2017-02-21 00:32 | kkremitzki | Note Edited: 0008394 | |
| 2017-02-21 00:33 | kkremitzki | Status | assigned => resolved |
| 2017-02-21 00:33 | kkremitzki | Resolution | open => fixed |
| 2017-02-21 00:33 | kkremitzki | Note Added: 0008395 | |
| 2017-02-21 00:33 | kkremitzki | Status | resolved => closed |
| 2017-03-13 16:02 | Kunda1 | Additional Information Updated |
