| 0002885 | Path | Bug | public | 2017-02-02 22:06 | 2018-01-22 18:42 |
| Reporter | mlampert | Assigned To | mlampert | ||
| Summary | 0002885: Dressups drop feedrate from commands | ||||
| Description | Dressups holding tags and dogbone do not insert feed rates for each command - which are needed by the post processor to generate valid g-code. The reason this has gone undetected for a while is because feed rates are sticky in g-code. As long as the first operation isn't dressed up it will set the feed rates which will get applied until changed. | ||||
| Steps To Reproduce | Create a Job for a part. As its only operation create a Contour operation Dressup the op with holding tags Inspect generated g-code and check for F parameters in each command. | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=15&t=20439 | ||||
Added forum link to the ticket |
https://github.com/FreeCAD/FreeCAD/commit/23f88c5d85c2128a116a362920a9faba09e03325 |
| 2017-02-02 22:06 | mlampert | New Issue | |
| 2017-02-02 22:06 | mlampert | Status | new => assigned |
| 2017-02-02 22:06 | mlampert | Assigned To | => mlampert |
| 2017-02-02 22:26 | Kunda1 | Note Added: 0008183 | |
| 2017-02-02 22:26 | Kunda1 | Additional Information Updated | |
| 2018-01-22 18:42 | wmayer | Status | assigned => closed |
| 2018-01-22 18:42 | wmayer | Resolution | open => fixed |
| 2018-01-22 18:42 | wmayer | Fixed in Version | => 0.17 |
| 2018-01-22 18:42 | wmayer | Note Added: 0010815 |
