| 0002886 | FreeCAD | Bug | public | 2017-02-03 00:05 | 2017-03-09 02:24 |
| Reporter | blacey | Assigned To | blacey | ||
| Platform | Apple | OS | macOS | OS Version | All |
| Summary | 0002886: FreeCAD.app loads libraries from /usr/local/FreeCAD.app/Contents/lib if they exist | ||||
| Description | The "relocatability" of the macOS bundle does not handle RPATHS that are set to the non-relocatable executable /usr/local/FreeCAD.app/Contents correctly. This results in libraries being loaded from /usr/local/FreeCAD.app/Contents/lib if they exist and superseding libraries within the FreeCAD.app loader path causing unexpected results and crashes. | ||||
| Steps To Reproduce | 1. Download the FreeCAD Qt5 build and install in /usr/local 2. Download the FreeCAD Qt4 build and place somewhere else 3. Launch the FreeCAD Qt4 app using the following: DYLD_PRINT_LIBRARIES=1 <path>/FreeCAD.app/Contents/MacOS/FreeCAD 4. This will cause a crash due to an unexpected executable 5. Use the following command to remove the invalid RPATH from the main executable install_name_tool -delete_rpath '/usr/local/FreeCAD.app/Contents/lib' FreeCAD 6. Launch again the following command: DYLD_PRINT_LIBRARIES=1 <path>/FreeCAD.app/Contents/MacOS/FreeCAD 7. Note that the app launches but it loads libraries from /usr/local/FreeCAD.app/Contents/lib 8. Dump the RPATHS using the following command: find <path>/FreeCAD.app/Contents/MacOS/ -name '*.dylib' -exec otool -l {} \; | grep -A3 RPATH | grep path | grep '/usr/local/FreeCAD' 9. Note that there are 9 occurrences of an RPATH pointing to the non-relocatable image /usr/local/FreeCAD.app/Contents/lib. Offending libraries: ../lib/libDriverDAT.dylib ../lib/libDriverSTL.dylib ../lib/libDriverUNV.dylib ../lib/libFreeCADApp.dylib ../lib/libFreeCADGui.dylib ../lib/libNETGENPlugin.dylib ../lib/libSMESH.dylib ../lib/libSMESHDS.dylib ../lib/libStdMeshers.dylib | ||||
| Tags | macOS | ||||
The scope of this fix entails the following: 1. Remove existing LC_RPATHS from dependent libraries before adding new LC_RPATHS because the old paths point to the original /usr/local location and take precedence over the new paths because the new are added after the existing 2. After copying an external library into the bundle, change the LC_ID_DYLIB to a bundle-local name (i.e. replace the absolute path name) |
I have implemented the aforementioned changes and added diagnostic information to the script using the python logging module. This will enable other developers to understand what the script does more quickly in case anyone needs make changes in the future. I will submit the changes in a PR once my Travis test build completes. |
Committed in FreeCAD master b52b94ae Thanks! (Resolving manually as MantisBT source-integration is not functioning correctly ATM. |
FreeCAD: master b52b94ae 2017-02-19 03:16:12 Details Diff |
Packaging: Set macOS dynamic loader paths * DYLD paths are set properly to prevent loading libraries external to the bundle a. LC_ID_DYLD is set to the basename of the library name (i.e. not the absolute path) when it is copied into the bundle b. Existing LC_RPATH entries in libraries are removed before adding the bundle-relative RPATH * Added configurable diagnostic logging to aid in debugging Fixes 0002886 |
Affected Issues 0002886 |
| mod - src/Tools/MakeMacBundleRelocatable.py | Diff File | ||
| mod - CMakeLists.txt | Diff File | ||
| 2017-02-03 00:05 | blacey | New Issue | |
| 2017-02-03 00:06 | Kunda1 | Tag Attached: MacOSX | |
| 2017-02-19 01:43 | blacey | Assigned To | => blacey |
| 2017-02-19 01:43 | blacey | Status | new => assigned |
| 2017-02-19 01:45 | blacey | Note Added: 0008354 | |
| 2017-02-19 07:02 | blacey | Note Added: 0008360 | |
| 2017-02-19 14:39 | Kunda1 | Status | assigned => resolved |
| 2017-02-19 14:39 | Kunda1 | Resolution | open => fixed |
| 2017-02-19 14:39 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-02-19 14:39 | Kunda1 | Note Added: 0008367 | |
| 2017-03-09 02:24 | Kunda1 | Changeset attached | => FreeCAD master b52b94ae |
| 2017-03-09 02:24 | Kunda1 | Status | resolved => closed |
