| 0002893 | TechDraw | Bug | public | 2017-02-10 09:15 | 2017-02-18 22:46 |
| Reporter | ian.rees | Assigned To | ian.rees | ||
| OS | MacOS | OS Version | 10.11.6 | ||
| Summary | 0002893: TechDraw viewer doesn't stop capturing clicks | ||||
| Description | In some cases, after TechDraw has been used, clicks in the regular 3D view cause FreeCAD to bounce back in to the TechDraw view. Note this is on Qt5.6, MacOS, my pivy is broken... kkremitzki tried reproducing it with a similar version of FreeCAD on Ubuntu 16.04 + Qt4, so I suspect it might be a MacOS and/or Qt5 issue. OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10047 +11 (Git) Build type: Debug Branch: 20151212-export-amf Hash: 227f046c3dae1d0521d8891eb78bc76d214050bd (Based off master 72d2349429cdba6beeaec93658ccd2315baa1d14) Python version: 2.7.13 Qt version: 5.6.2 Coin version: 3.1.3 OCC version: 7.0.0 | ||||
| Steps To Reproduce | 1 Start FreeCAD 2 New empty document (my FreeCAD default is to open in Part Design - perhaps opening Part Design is necessary?) 3 Select TechDraw workbench 4 Insert new drawing from default template 5 Go back to 3D view 6 Select Part Design workbench 7 Make a new Part 8 Make a new Body 9 Add a sketch on XY plane 10 Select the sketcher tool to draw a line 11 Start to draw the line on the sketch What I see is that the view flips back to TechDraw. I'd expect drawing the line to work as normal. | ||||
Not reproducible with: OS: Ubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10047 (Git) Build type: debug Branch: master Hash: 72d2349429cdba6beeaec93658ccd2315baa1d14 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 OCC version: 7.1.0 |
Can't reproduce on this either: OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10074 (Git) Build type: Unknown Branch: master Hash: 34a3039577b20fcf69300f84ff59a140fe690aa6 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.0.0 |
Checked that the same issue does not happen with the latest dev build from the CI system (Qt4): OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10101 (Git) Build type: Release Branch: (detached from 99fa203) Hash: 99fa203f323927b0dd027420d4421b577b7420c3 Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 |
I've updated PySide2 and now the bug seems to have fixed itself. Sorry for the noise! |
| 2017-02-10 09:15 | ian.rees | New Issue | |
| 2017-02-10 12:04 | Kunda1 | Project | FreeCAD => TechDraw |
| 2017-02-10 18:32 | wandererfan | Note Added: 0008266 | |
| 2017-02-10 18:33 | wandererfan | Status | new => feedback |
| 2017-02-12 17:05 | wandererfan | Note Added: 0008276 | |
| 2017-02-16 18:22 | ian.rees | Note Added: 0008325 | |
| 2017-02-16 18:22 | ian.rees | Status | feedback => new |
| 2017-02-18 22:46 | ian.rees | Assigned To | => ian.rees |
| 2017-02-18 22:46 | ian.rees | Status | new => closed |
| 2017-02-18 22:46 | ian.rees | Resolution | open => unable to reproduce |
| 2017-02-18 22:46 | ian.rees | Note Added: 0008352 |
