| 0002894 | FreeCAD | Bug | public | 2017-02-10 11:13 | 2017-03-15 17:47 |
| Reporter | emanuele | Assigned To | eivindkvedalen | ||
| Platform | Linux | OS | Ubuntu | OS Version | 16.10 |
| Summary | 0002894: Using units as alias corrupts the design | ||||
| Description | When changing the alias in a spreadsheet from a valid name to a reserved value, does not raise any alert but corrupt the design when you reopen it. Tested setting the alias to t, mA and mol, but should apply to all units described in src/App/FreeCADInit.py and used by the expression parser. | ||||
| Steps To Reproduce | Open FreeCAD Press the "create new document" button Switch to the Part workbench Press the "Create a cube solid" button Switch to the Spreadsheed workbench Press the "Create a new spreadsheed" button Double click on the new Spreadsheet in the document tree Write 4 in cell A1 Right click on cell A1 Open the Alias tab Set the alias for this cell as "myAlias" (without quotes) Click OK Doble click on the Cube in the document tree Set the the Length as Spreadsheet.myAlis Go back to the Spreadsheet and change the value in A1 to 6 Check in the view that the drawing has updated correctly Save the document and close all Reopen the document: everything should be ok Open the Spreadsheet Right click on cell A1 Open the Alias tab Change the alias for this cell from "myAlias" to "mA" Check in the view that the drawing of the cube is still correct Go back to the Spreadsheet and change the value in A1 to 10 Check in the view that the drawing has updated correctly Save the document and close all Reopen the document: everything will be screwed up (the names of the solids changed, their sizes and the data in the spreadsheet lost, etc.) | ||||
| Additional Information | Reproduced on version: OS: Ubuntu 16.10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6707 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f Python version: 2.7.12+ Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | spreadsheet, units | ||||
Please open a forum thread on https://forum.freecad.org/viewforum.php?f=8 to discuss this issue and bidirectionally link thread <=> ticket. Thanks. |
Opened forum thread https://forum.freecad.org/viewtopic.php?f=8&t=20587 to get some feedbacks from other users. Thanks. |
Branch for testing added: https://github.com/eivindkv/FreeCAD/tree/Fix_issue_2894 |
FreeCAD: master 338ca556 2017-03-05 23:27:19 Eivind Kvedalen Committer: yorik Details Diff |
Spreadsheet: Fixed issue 0002894: Unit strings could be used as aliases. |
Affected Issues 0002894 |
| mod - src/App/Expression.cpp | Diff File | ||
| mod - src/App/Expression.h | Diff File | ||
| mod - src/Mod/Spreadsheet/App/PropertySheet.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/TestSpreadsheet.py | Diff File | ||
| 2017-02-10 11:13 | emanuele | New Issue | |
| 2017-02-10 11:21 | Kunda1 | Tag Attached: spreadsheet | |
| 2017-02-10 11:23 | Kunda1 | Note Added: 0008262 | |
| 2017-02-10 11:23 | Kunda1 | Status | new => feedback |
| 2017-02-10 15:17 | emanuele | Note Added: 0008264 | |
| 2017-02-10 15:17 | emanuele | Status | feedback => new |
| 2017-02-10 16:10 | Kunda1 | Tag Attached: units | |
| 2017-02-11 17:53 | eivindkvedalen | Assigned To | => eivindkvedalen |
| 2017-02-11 17:53 | eivindkvedalen | Status | new => assigned |
| 2017-02-13 22:40 | eivindkvedalen | Note Added: 0008290 | |
| 2017-03-07 16:46 | yorik | Changeset attached | => FreeCAD master 338ca556 |
| 2017-03-15 17:47 | wmayer | Status | assigned => closed |
| 2017-03-15 17:47 | wmayer | Resolution | open => fixed |
| 2017-03-15 17:47 | wmayer | Fixed in Version | => 0.17 |
