| 0002897 | FreeCAD | Bug | public | 2017-02-10 21:17 | 2017-03-07 12:07 |
| Reporter | Kunda1 | Assigned To | vejmarie | ||
| OS | Travis OSX | ||||
| Summary | 0002897: OpenGL methods have been deprecated starting in MacOSX 10.9 | ||||
| Description | Looks like some OpenGL methods have been deprecated in favor of newer methods: See http://stackoverflow.com/questions/30361168/how-to-fix-my-deprecated-use-of-gluortho2d Errors thrown by TravisCI OSX build in https://travis-ci.org/FreeCAD/FreeCAD/jobs/198293796#L3172-L3178
See also https://travis-ci.org/FreeCAD/FreeCAD/jobs/198293796#L3245-L3259 | ||||
| Tags | macOS | ||||
Reminder sent to: blacey Just sending @blacey an FYI about 0002897 |
@vejmarie, do you want to take this one while you are messing around with OpenGL? It looks really straight-forward if you read the stackoverview link included in the description. |
Assigned to @vejmarie per his Gitter post to take a look. |
I just checked, and this stuff is located into dead code (aka it is never called anywhere in FreeCAD and we can even comment the function). I think we shall just comment it for the moment, and remove it in a couple of months if nobody wants to re-activate it. What do you think ? |
Thanks @vejmarie, your plan sounds fine by me but perhaps we can just remove the legacy code and re-add if necessary. Adding @wmayer so he can weigh in. |
+1 for just deleting unnecessary code - it's less work and just as safe. |
I just checked, and this stuff is located into dead code GLImageBox.cpp is part of the Image module and maybe rarely used but it's definitely not dead code. |
Hi wmayer, The call is there void GLImageBox::resizeGL( int w, int h ) { glViewport( 0, 0, (GLint)w, (GLint)h ); glMatrixMode( GL_PROJECTION ); glLoadIdentity(); gluOrtho2D(0, width() - 1, height() - 1, 0); glMatrixMode(GL_MODELVIEW); } and the ResizeGL function is never called in FreeCAD, that is why I proposed to remove it from the file by commenting it. GLImageBox.cpp is a old stuff. I can migrate it to a newer GL code, but the issue I faced was how to test it, as it is not called into FreeCAD ;). Ok I can call it and see if it work, but I even have some doubt on that because it will requires to change the viewprovider call to call the resize at the right time. "lot" of work for something currently unused ;). |
Ok, I found a way to test the stuff. I will push for a PR within the next couple of minutes to close that issus |
This has been fixed in PR 0000584 I think we can close the issue |
| 2017-02-10 21:17 | Kunda1 | New Issue | |
| 2017-02-10 21:17 | Kunda1 | Tag Attached: MacOSX | |
| 2017-02-10 21:32 | Kunda1 | Note Added: 0008267 | |
| 2017-02-10 21:33 | Kunda1 | Project | Path => FreeCAD |
| 2017-02-10 22:38 | blacey | Note Added: 0008269 | |
| 2017-02-16 02:59 | blacey | Assigned To | => vejmarie |
| 2017-02-16 02:59 | blacey | Status | new => assigned |
| 2017-02-16 03:00 | blacey | Note Added: 0008319 | |
| 2017-02-20 22:51 | Kunda1 | Target Version | => 0.17 |
| 2017-02-24 20:20 | vejmarie | Note Added: 0008426 | |
| 2017-02-26 00:41 | blacey | Note Added: 0008437 | |
| 2017-02-26 05:34 | ian.rees | Note Added: 0008438 | |
| 2017-03-03 16:04 | wmayer | Note Added: 0008527 | |
| 2017-03-03 16:13 | vejmarie | Note Added: 0008528 | |
| 2017-03-03 20:18 | vejmarie | Note Added: 0008529 | |
| 2017-03-03 21:46 | vejmarie | Note Added: 0008534 | |
| 2017-03-07 12:07 | wmayer | Status | assigned => closed |
| 2017-03-07 12:07 | wmayer | Resolution | open => fixed |
| 2017-03-07 12:07 | wmayer | Fixed in Version | => 0.17 |
